Motorswap not starting HELP!!!!!!!
Me and my friends did our first motor swap on a 98 z-28, we took the old ls1 out and installed a new Gen III Iron 5.7. During the motor swap we installed new clutch, ls6 intake, long tube headers, and all new sensors, Anything from crank sensors to oil pressure sensor. We also ran black nylon hose for a new fuel line going into new fuel rails.
So after we got everything in and after we primed the system of course, we go to start it and the only thing that happens is that it turns over but no fire. So we checked and we have no spark and the fuel pump is not kicking on. Also we have no gauges.
We have checked all wires, fuses and relays and everything seems fine, we have been looking all week for anything but we are having no luck. So now we are asking for help. Any ideas?
And negative, we are not getting a rpm signal. We are not getting any signal on gauges. No rpm, no fuel tank level, no oil presser, no water temp, and no battery. Which is wierd bc we are getting the motor to turn over but its not giving me the volts on the battery. The only light that comes on is security?
Can a relay go bad just sitting? I have no proplem buying a new one but i dont want to start chasing problems.
If the CAN BUS is down nothing will work on the cluster except for maybe the speedo, depending on what year it is.
Check for DTC's. My guess is you have some.
As mentioned check all of your grounds. Does the BJB have power to it?
If all you did was just an engine swap it sounds like you forgot to hook something back up.
again. This could be completely wrong maybe someone else can chime in.
I doubt it is a relay or fuse. Your alternator might not be plugged in or something silly like that. You would still get power from the battery in this case though. There is a ground there from the block to the frame as well. I know everyone has said to check grounds repeatedly, but this is NOT a VATS issue, it's a power supply issue. If it were VATS, the engine usually starts then dies, and you will have the security light, as well as power to your cluster.
Check all wires from the battery. If needed, replace them. You might just have a short in your ignition circuit, or something is hooked up backwards somewhere, perhaps at the starter. I don't know, but I am just thinking out loud here. Check the power going into the fuse blocks too, (also on the battery/ignition circuit) and see what is going on there. You should a lot of hotwires throughout the car. Definitely anything that is hooked to the battery should have between 11-12v at all times, key or no key. If one of these wires is shorted out, then it could cause your complete loss of power, mainly the huge 2 and 4 gauge wires you see in the engine compartment. Check them all for power and ground, starting at the battery, and slowly working your way to the key, coil packs, fuel pump etc. Most of the "hotwires" or "hot at all times" wires are RED, PINK, or sometimes YELLOW or ORANGE <(some cases in the dash I've found).
A good wiring schematic is very useful here in figuring out what needs to have power and when.
