Benchtop Harness help
Old Apr 1, 2018 | 07:24 PM
Explicit_Spade's Avatar
Default Benchtop Harness help
I attempted to build my benchtop harness this weekend. I wanted to use 2 switches, one for powering up the benchtop and the other as an ignition switch. I believe I have everything close to being correct, but HPTuners is reading that the interface is connected, but not reading the "car" to be on. Hopefully someone can tell me what I am doing wrong.
This is how I currently have everything ran. Both switches appear to be working in this configuration.
Benchtop Harness (Not Working)
Old Apr 1, 2018 | 11:01 PM
EFIHARNESS's Avatar
run a ground to j1-1, 40 not to 60
B+ also to J1-57
some controllers also need ign to J1-75.
not all controllers need these, but all will work if hooked up like this.
efilive has a write up for this. Steve
Old Apr 3, 2018 | 12:10 AM
Thank you for the reply EFIHARNESS!
I hate to admit this, but I picked up a multi-meter today and found that my power source positive and negative were backwards. I switched it around and re-adjusted my switches accordingly and everything is working.
Old Apr 5, 2018 | 02:16 AM
80Z28FI's Avatar
Default gen 3 setup i used
this the the gen 3 setup i came up with from reading a wiring diagram. programed several pcms with it. 12v 1amp charger. box setup like u want
Attached Thumbnails Benchtop Harness help-benchtop4.jpg   Benchtop Harness help-benchtop-harness.jpg
Old Apr 6, 2018 | 07:13 PM
toplessHO's Avatar
do yourself a favor and use a battery(small one) for UPS unit,garden tractor,etc.
it acts like a filter to cut out the ripple.
