Crank sensor RPM to call for fuel
I am going to try this tinker toy. I can set the minimum voltage to 9v and the high to 12.6 for a starter safety switch. I was trying to do it with the fuel circuit but I think this might be a better option.
I ls swapped a 74 caprice not to long ago. It had a vvt/dod 5.3. We removed everything and swapped a performance cam, 4x gear etc in its place. Well not knowing any better we reused the original vvt cam cover.
Well with a vvt/dod delete u cant use that cover. It positiones the cam sensor farther from the cam gear. We couldnt get an injector pulse. Even Verified cam pulse with hptuners. Zero.
Ended up Pulling the vvt cover and replaced with a ls2 cover and car fired right up. No issues since.
I have a 47 Chevy Pickup that has an old floor start switch. The factory style ignition does not have a crank position built in. I am trying to keep the factory feel of the truck, but I don't want to be able to accidentally hit the start switch while its running.
