Slight rough idle
Old May 21, 2018 | 09:36 PM
mbarb55's Avatar
Default Slight rough idle
Hey guys, I have a 1999 firebird ws6 m6 with a rough idle that seems to get slightly worse after it warms up. It feels like a misfire but I'm unsure. It feels fine driving, iv also noticed that my mpg seems to have gotten worse. (I don't have any exact numbers, sorry)
Things I have done/replaced:.
Cleaned maf x2
cleaned idle air control valve x2
Replaced spark plugs
New msd wires
My mods:
K&N cold air intake
Borla cat back
(I suspect and one point this car ran Nos. I found a braided brake line going from the firewall to the hatch)
I've also questioned if potentially this car has a crappy tune but can't prove it. I've attached logs from my car driving and idling. I'm hoping that someone can read the logs and let me know if something isnt right. I have a suspicion it may be o2 sensors but I'd like to be sure if that is possible .
(Apologies if this is in the wrong place)
Thanks in advanced everyone.
File Type: csv
Old May 23, 2018 | 01:46 AM
mbarb55's Avatar
Is anyone able to help?
Old May 23, 2018 | 05:21 AM
Fuhnortoner's Avatar
Vacuum leak.
Old May 23, 2018 | 05:44 AM
mbarb55's Avatar
I agree it could be a vacuum leak however I checked everything I can see and haven't found anything. If the logs don't show anything useful I will have to get the pcv system checked.
Old May 23, 2018 | 05:45 AM
The logs show an idle MAP of ~5psi, which correct me if im wrong is low for a stock cam.
Old May 23, 2018 | 08:41 AM
mbarb55's Avatar
If that is indeed low, is that indicative of a vacuum leak or something else?
Old May 23, 2018 | 09:31 PM
mbarb55's Avatar
Any other assistance is appreciated
Old May 24, 2018 | 12:30 AM
If I were you, I'd make a boost leak pressure tester similar to the one below. I made mine out of a plastic PVC cap and a valve stem.
