Even Weirder A/C Issue
I''m having an A/C issue. My A/C, once turned on, will not SHUT OFF even if all of the switches are turned off. The other day I was driving on the freeway with the A/C on and when I exited and parked I turned everything on the dash A/C related off. I got back in it 10 minutes later and took off and noticed that the A/C was running as I could feel cold air coming out of the vents. I thought maybe it was just left over air in the vents so I kept driving... 30 minutes later I'm back at my shop and there is still cold air coming out the vents. The "A/C" button on the dash is NOT depressed-nor is it illuminated. The fan is on "0", and with the hood up and engine idling I can see the compressor clutch is still engaged. It finally froze my evaporator core and then the belt promptly popped off. So, now I have no A/C. I have not put the belt back on yet because I'm not sure what is causing the issue. I guess I need to start there. I should mention that as long as I don't turn the A/C on, it won't auto-run.. It's only when I turn it on, then try to turn it off that it won't release the compressor clutch.
My next step is to duplicate the problem, and then check the wires that cycle the compressor clutch for current. If there is current, then I know that something is wrong with the tune, the OS, or the wiring. If no current is present, and the clutch is still engaged, I will know it's a mechanical issue with the compressor.
Has anyone else had, or experienced, this problem before? It's a 411 PCM running the 12212156 (yes I guessed at the OS #'s so don't shoot me if I was off a # or three) OS. I did convert it over to electric fans which required removing a wire from the harness that used to cycle the MAX A/C door, and no longer using it (wrapped up inside loom). Could that have something to do with it?
