0411 PCM , Tahoe pump and Dakota Digital gauge?
Hi, first time poster long time listener. Will below setup work to get fuel level to my gauges?
0411 PCM (have hptuners )
2002 Tahoe fuel pump assembly (delco mu1615). wire the sensor signal back to PCM as per factory
Dakota Digital VHX gauge cluster with BIM/obd2 module.
If not, can I pull a signal wired directly from the sensor, assume this assembly would be standard 40-250ohm signal then I can just wire directly to my VHX gauge? I want to be sure either will work before I weld up the tank for the pump, I don't want to add a standalone level sensor unless I have to. Actually I'd prefer to wire it up directly and not the PCM as I want to have as few things relying on the BIM module as possible (as you can't use it simultaneously with HPtuners, can't split output the signal)
thanks!
thanks!
