Microsquirt no rpm sync
Old Jul 24, 2018 | 11:09 PM
Turbo5's Avatar
Default Microsquirt no rpm sync
I have turbo 5.3 ls using a microsquirt v3 controller. I ordered the plug and play harness from diy auto tune with microsquirt package. I had the car running pretty good but then it started dying intermittently at low rpm. Now it won't start at all and shows no rpm sync on tuner studio. All other gauges are working. I did notice I would have a small amount of rpm when letting of the key for just that split second. Other than that I have no signal. I replaced crank sensor and also check to have ground and 12v at plug. Still says no sync. I ran spark test with tuner studio and could see spark coming out of coils. I have no spark and no fuel now. I am new to all this as this is my first microsquirt build. What else should I check?
Old Jul 25, 2018 | 06:31 AM
JoeNova's Avatar
Restricted User
Hook up jumper cables or a charger to it. Low voltage and low cranking RPM will cause it to not sync RPM while cranking.
Old Jul 25, 2018 | 09:12 AM
Turbo5's Avatar
I did try that with no luck. The battery is brand new.
Old Jul 25, 2018 | 09:29 AM
JoeNova's Avatar
Restricted User
Any chance you're getting the cam and crank sensors confused?
Old Jul 25, 2018 | 09:33 AM
Turbo5's Avatar
The controller only has a crank sensor. I thought it was a ground problem but I cleaned them and tightened them up.
Old Jul 25, 2018 | 09:35 AM
JoeNova's Avatar
Restricted User
Yes, but the crank sensor connector will plug right into the cam sensor at the back of the valley cover. Common mistake.
Old Jul 25, 2018 | 10:24 AM
Turbo5's Avatar
Ok I doubled checked. I am sure it is in crank sensor located on the passenger side just above the starter.
Old Jul 25, 2018 | 10:30 AM
JoeNova's Avatar
Restricted User
When you connect it, are all of the sensors reading OK? TPS, MAP, CLT?
Old Jul 25, 2018 | 10:35 AM
Turbo5's Avatar
Yes everything else seems to be reading fine.
Old Jul 25, 2018 | 11:08 AM
JoeNova's Avatar
Restricted User
Email me the tune, I'll use it to fire up one of my micro controlled setups and rule out any software issues.
joefields1987@gmail.com
Old Jul 26, 2018 | 11:07 PM
Turbo5's Avatar
So talked to guy at diy auto tune and realized I had a 24x reluctir wheel instead of 58x. My engine is an 2000. So I went back with the original tune they sent me and changed in the ignition setting to ls1. I am now getting rpm and it gets to fire but acts like the timing is to advanced then blows the coil fuse. So i tried another fuse and same thing. It lit then blew the fuse and died. What would case the coil fuse to continue to blow?
Old Jul 31, 2018 | 09:33 AM
Mymonte666's Avatar
you dwell time settings can cause the coils to overheat and blow fuses.
Old Jul 31, 2018 | 09:56 AM
Turbo5's Avatar
Thank you guys for your help! You were correct on the dwell setting! I am now up and running again finally. Where would I find a good tune for my set up. 5.3 ls 24x 7875 turbo, sloppy stage 2 cam, btr springs, microsquirt controller,....
Old Jul 31, 2018 | 10:21 AM
JoeNova's Avatar
Restricted User
You have about the most common, plain jane, overdone setup in the history of engine setups.
So I'd imagine you would get a base tune from someone at the sloppy mechanics facebook page.
Old Jul 31, 2018 | 10:45 AM
Turbo5's Avatar
Thanks
