Ecu 411 with gm e85 flex fuel sensor
Old Jul 27, 2018 | 12:08 AM
Kurtis2short's Avatar
Default Ecu 411 with gm e85 flex fuel sensor
I have a 411 ecu hard throttle cable is there any way to for it to read the gm 13577429 flex fuel sensor ? Any one able to add that or program so it’ll read it correctly
Old Jul 27, 2018 | 01:44 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Maybe, but you will find much more info if you do it with a P59 computer. It is still a cable throttle computer, but I believe a few pinouts are different.
Old Jul 27, 2018 | 01:59 AM
What did a p59 come in ?
Old Jul 27, 2018 | 02:21 AM
subeone's Avatar
You can use the 0411 if not going over 15 psi
Old Jul 27, 2018 | 12:01 PM
Mhm lsa is only pushing 11psi with a cam is there a certain program I should use or run
My lsa
Old Jul 28, 2018 | 12:55 AM
gametech's Avatar
2004 GTOs, and apparently some vans. I do not know what else. The only ones that have lean cruise enabled (which you did not ask about and may be irrelevant) are the Aussie pcms from the GTOs. It is just an oddball pcm where pretty much everything works. The earlier ones lack a few minor capabilities, and the later ones started getting rid of real VE tables.
Old Aug 13, 2018 | 08:06 PM
Monte4ever's Avatar
I use OS 12216125 with my 411 ECM. Look for a 2002 Tahoe file with the Flex Fuel Tables populated.
Old Sep 24, 2018 | 11:11 PM
Mike Morris's Avatar
No air bag code or SES light ?
Old Sep 25, 2018 | 10:03 AM
TPIZ92's Avatar
both show up though the ses light I think did eventually go out for me after alittle tweaking. Airbag light stayed on for me.
Old Sep 25, 2018 | 10:28 AM
Ugh. There has to be a way to get rid of it
Old Sep 25, 2018 | 01:19 PM
truckdoug's Avatar
have you tried switching Systems > Platform > F body?
