Which ECM, and why?
Old Jul 29, 2018 | 06:43 PM
Default Which ECM, and why?
Okay, if you could run ANY ECM on your ride, which would you choose? Looking for possible replacement of my MAST electronics. Money is no issue, and of course I’d need a custom harness as well.
Assuming I ditch my MAST electronics, which at this point is a possibility, due to a wideband issue, I’d love to know which way to go. The MAST stuff runs my gauge controls, has a simple to use software program, and is very high quality, so if I swap, I’d like something similar. GM has made a gazillion ecm’s, so tell me what’s the best in that line, if you suggest GM. Does GM offer a wideband setup?
Let me know what’s out there guys...
Old Jul 29, 2018 | 07:28 PM
B52bombardier1's Avatar
What engine? Transmission?
Rick
Old Jul 29, 2018 | 07:47 PM
truckdoug's Avatar
the m90 was/is pretty advanced. perhaps the holley dominator or the fast xfi 2.0 are on that level. MS3 Pro for a more savvy diy type or go upmarket like MoTeC maybe?
are your gauges canbus or are you using the built in drivers on the mast ecm?
Old Jul 29, 2018 | 07:51 PM
434” RED sleeved block with Mamo 265 LS7 heads. Mamo ported MSD intake, solid roller 254/268. T56 manual, with stage 2 kit. Made 616 last week, with faulty wideband circuit (not the sensor)
Old Jul 29, 2018 | 07:54 PM
Analog gauges, driven from the M90 ECM.
I love the MAST setup, but if we can’t get this wideband figured out soon, I’m done. Been screwing around with issues since January, and I’m ready to put my ECM issues to bed.
Old Jul 30, 2018 | 09:44 AM
truckdoug's Avatar
does mast support their computers anymore? I cant even find them on their new site
Old Jul 30, 2018 | 06:29 PM
Yes. Talked to Damon today, and I’m sending him the ECM.
I will keep you guys posted on this. Thanks for the responses.
Old Aug 6, 2018 | 09:12 PM
rpturbo's Avatar
If your swapping, I would probably go with a Holley Dominator setup. It simply has the most options for the $, and is fairly user friendly. With built in controls for N20, boost, traction control etc, it's hard to beat it.
Old Aug 7, 2018 | 08:25 AM
Mymonte666's Avatar
I prefer megasquirt because it's flexibility, options and community support. Open source software and hardware. And of course price.
Haltec is another good option, but up there on the price range.
I stay away from microtec.
Old Aug 7, 2018 | 11:19 AM
cam's Avatar
cam
Work with your tuner, if thats you? Stock GM or Holley will have the best tuning support. Holley maybe moreso these days
Old Aug 8, 2018 | 06:49 AM
Thanks again for the suggestions guys. I should know by the weekend which direction I’m going with this.
