another IAT sensor question - works after 15-18 mins
Hey, I'm having an issue where my PCM doesn't read IAT input for about 15-18 minutes. It sits at -31 then after time it all of a sudden starts to read like normal. Its very aggravating & since I'm on ethanol its idling excessively rich.
I've checked my wiring about 200 times & its all correct & the connections are good. I thought maybe the sensor is bad but why would it start working after a certain amount of time?
Is there any setting on the PCM I can check via HPTuners?
Have you recently written a calibration using HPT4? Reason I ask is I am dealing with a PCM that will not command fans on but fans work and relays work when jumpered. Wondering if it's a bad pcm for stupid reasons or a bad pcm for HPTuners reasons.
