4l80e always reads -38
Old Sep 10, 2018 | 04:19 PM
Crysis's Avatar
Default 4l80e always reads -38
I have a 99 4l80e and its been reading -38 all the time I already replaced the sensor what can this be??
Old Sep 10, 2018 | 06:57 PM
truckdoug's Avatar
-38 what? fluid temp? is the 80e native to your vehicle or is it a swap, altered harness? it could be wired wrong.
Old Sep 10, 2018 | 07:25 PM
Crysis's Avatar
Yeah its swap I did the sloppy mechanics 4l80e harness modification and blew up the first 4l80e which had trans temp working put this one in and hasn't been working
Old Sep 10, 2018 | 08:14 PM
rpturbo's Avatar
What exactly is "blew up the first 4l80e?" Less is not more when asking for help
Old Sep 10, 2018 | 08:19 PM
Crysis's Avatar
Haha its a turbo 5.3, the transmission wouldn't shift anymore after some pulls
Old Sep 10, 2018 | 08:36 PM
truckdoug's Avatar
is the internal trans harness wired as before?
Old Sep 10, 2018 | 08:43 PM
Crysis's Avatar
What do you mean?
Old Sep 13, 2018 | 06:12 PM
Crysis's Avatar
Still reading -38 any ideas why
Old Sep 13, 2018 | 08:52 PM
Darth_V8r's Avatar
Moderator
-38 DA? -38 degrees latitude? -38 dollars in checking account?
Old Sep 13, 2018 | 08:59 PM
And here I thought I was the only one in the dark...
Old Sep 13, 2018 | 10:34 PM
truckdoug's Avatar
he said he's got an 80e, not a 60e
Old Sep 13, 2018 | 11:01 PM
No mention in this thread of a 4L60E....
Old Sep 13, 2018 | 11:18 PM
pdxmotorhead's Avatar
Well it evens out,, there is no real problem description either.. LOL
So I'll say -38 is way off... should be more like +237
Old Sep 14, 2018 | 01:05 AM
Crysis's Avatar
Come on what else is -38 obviously temp, you guys gotta be kidding if you don't know just don't reply don't try to be smart or funny, i felt it was pretty obvious what i meant
Old Sep 14, 2018 | 10:23 AM
-38 is WAAAAY below freezing. So it ain't temp, dude.
Old Sep 14, 2018 | 11:46 AM
truckdoug's Avatar
the trans fluid temp pressure modifier table goes down that for guys that live in canada.
its a resistive sensor so you need to verify it's getting the 5v it needs and the return signal is going to the right pin on the pcm. missing either will make it read -38 temp. I went thru this with the older 80e I use in my turbo truck. my fix was to delete the trans temps sensor DTCs
Old Sep 14, 2018 | 12:30 PM
Crysis's Avatar
Oh so does urs still read like that? And yeah its getting 5v
Old Sep 14, 2018 | 12:53 PM
truckdoug's Avatar
No, I can't log anything at all. It wont come up in channels. There is nowhere for it to acquire data.
I only did that so my trans tune segment would not try and adjust shift pressures for it being cold as ***** (technical term for -38ºF)
What is the output from the sensor reading in voltage? probably somewhere in the 2-2.5v range at like 80º --just a guess.
If the sensor is getting 5v and you're getting an output voltage then the problem lies in the signal return to the pcm. Either the trans pinout is wrong or a connection isn't being made somewhere.
I'm not sure what pin gets the temp signal...you'd have to look on lt1swap.com for that probably
Old Sep 14, 2018 | 01:46 PM
Crysis's Avatar
Oh ok ill check that this weekend thanks
Old Sep 14, 2018 | 02:04 PM
truckdoug's Avatar
word let us know how it turns out. we love a good mystery.
