mpvi2+wideband when?????
For P01 and P059 we use innovate LC-2 with a serial to usb adapter and plug it into a second usb port. Works great!.
They had a non working model on display. For P01 and P059 we use innovate LC-2 with a serial to usb adapter and plug it into a second usb port. Works great!.
So when HP annouced a projected release date for November were they specific if the PRO is for both or just the canbus versions to start and then for analog at a later date?
That's always been the marketing strategy. Release what gets the most sales first (obvious to do that) and then wait months to work on and release a product with less sales volume.
For example (EFI live for the (98's, HPT tuners for the (98's), Racetronix for the (98's) and so on
I'm ready to buy and have been for months, but pretty much useless if I can't data log with it. So I still have to use EFI Live V1 to data log which is analog. The cost to upgrade EFI live to V2 to get serial is the same as purchasing HPT tuners and even then no custom OS for 98's with EFI Live unless I change the PCM to 99-2002. So the better solution is HP with Pro.
If all you guys are wanting to do is log wideband then to hell with that pro version. The serial port works awesome and its super simple. Just get you a serial to usb adapter and plug it in to a usb on your laptop and HP Tuners will find the data stream and log it. You dont have to setup anything. Of course you need to select the wideband in the serial input of your scanner. HP Tuners already has it all configured for most of the popular widebands.
I was using my ac pressure switch and trying to get the right offset so my actual afr was matching what hp tuners was logging. If you are trying to do that then you need to throw that **** in the bushes. The serial port deal rocks!
Lol.... I have probably 10-15 widebands ranging from $200 to a $1000 and have cheap sensors and also expensive lab grade sensors. I run 2 widebands in 99% of the vehicles I tune, one lab grade and one innovate or aem and guess what, they are within .1 each other. If your relying on a wideband your doing it wrong anyways. There is no magic afr so if its makes peak power at 12.5 vs 12.6 does it matter? A wideband is just a tuning tool and a reference, in the end the spark plugs tell you what you need to know. Ground offsets with analog are more of an issue than using serial and a cheaper wideband. Once you use serial you wont use analog...We have been using serial for 10+ years.
sorry man I just cant give any love to innovate. every single one of their products i've used has been garbage.
dont conflate my love of the ballenger WB with an inability to tune a motor, read plugs etc.
I know you've been in the game a lot longer than me, but that doesn't make my experience null and void.
cherry picking that argument and leaving out the pressure sensors? thats not cool. what are you doing to log fuel pressure or drive pressure with the mvpi2?
I know you have skin in this game, you sell these products and are a paid sponsor here. I respect that. I don't however have to follow your line of thinking that the new is the best way.
I never said the MPVI2 is better but the MPVI1 is discontinued and the MPVI2 is the replacement weather you or I like it. It has nothing to do with selling them, honestly I made more on MPVI1 vs the 2. I just gave solutions to logging widebands with a MPVI2 with no analog inputs. I dont even use the analog inputs on my MPVI1, serial is faster and no ground offsets from vehicle to vehicle. We hardly ever log fuel pressure with hpt or efi, less than 1% of the time. If we suspect there is an fuel pressure issue we either log in the dyno, with nitrous/ boost controller or just put a fuel pressure gauge on the vehicle and video it while on the dyno. We do the video the most since its the fastest and it usually only takes a single pull to see a fuel pressure issue.
Innovate is not the best or close to it but the average person tuning there own single vehicle doesnt need a $400 wideband. If we have a lc2 or 4.9 sensor act up we just throw it away and move on. In the end most of the people will tune wot, part throttle and then turn on CL and use the fuel trims for part throttle so a high dollar wideband wouldnt help them any over a lc2 IMO. I dont think your ballenger WB made your tune any better vs if you used an AEM, innovate, plex or any other other wideband. Im not knocking a ballenger, I have one on my dyno and it use it daily.
What exactly is the problem with innovate? i been having one for about 2-3 years and I've never had an issue with it that I know of. What should i be looking for?
if yours has behaved, thats rad. no more for me please.
The following users liked this post:
n2xlr8n66 (09-12-2021)
I'm with Doug on the Innovate stuff. The one I had was cool for a short while and it started getting weird. I was new to tuning at the time so I thought it was me. Even worse it wasn't consistently bad initially making the problem more difficult to spot. Even with a new sensor the problems continued. Once I realized I was chasing my tail because of the wideband I bought an AEM, went serial input and haven't looked back. I would have gone to one of the CAN based models but my mainstay are non-CAN Gen III cars.
