Hp tuner
With that being said I had the same issue youre having. If I had it in drive it would hang on the 2-3 shift everytime. So I would launch in D then after the the 1-2 i would put it in OD until the 2-3 happened it would shift fine at WOT in OD theen I would drop it back into D so it wouldnt make a hard 3-4 shift after I let out at high rpm. Thats not good on the 4l60e. I messed around with the tune and nothing helped the issue. I cant remember exactly what the issue was while writing this but after I rebuilt the tranny all was good havent had the issue since
https://forum.hptuners.com/showthrea...Table-Software
I always set my mph pretty low compared to actual. (Ecu reads mph first thin, rpm 2nd for the shift). Thin set your desired rpm shift point to what u want it to shift at. I always make my rpm rev limiter a couple rpm higher than my shift points.
So lets say 6500 shift point.
Engine rev limiter to 6800 rpm.
Speed about 5-10 mph less than recorded at rev limiter.
This should fix it, as long as tune is correct.
U can also raise your line pressure, to help make the shifts on time and not so sloppy, and u can Lower shift times for faster shifts.
i set my rpm. then i note the mph its should be shifting at. I'll start at that mph and work my way up or down. Might have to flash it a couple times, but thats what gets it correct for me. understand that if you have a worn in trans with some miles on it, youll need to command a little sooner. So dont think something is wrong if you command a shift at 46mph and it dont do it till 50. Sometimes you gotta lower or raise the rpm too.
I didn't look at your file, I'm just speaking the truth about WOT shifting a 4L60E repeatedly.
