P0303 needing help!
Old Nov 2, 2018 | 06:56 PM
2010Imperial's Avatar
Default P0303 needing help!
Hi,
First off, 2010 Camaro SS, auto, 35,000 miles. Engine was running perfect, but I had a small gas leak from when I flipped the fuel rail ( I thought I'de be good not removing the bracket that was in the back and it bent the fuel rail). So I go and put on some JEGS fuel rails and converted to -6AN. Started it up and started spitting and clunking. Then just died. Now I can't even get the thing to turn over! Engine is locked up.
Can someone please offer some advice? Or maybe have this happen to them?
I pulled the code P0303, which I know that is an error code for a misfire. But how does that lock the engine up? Any and all help appreciated.
Old Nov 2, 2018 | 09:00 PM
B52bombardier1's Avatar
My suspicion would be that you have hydro locked a cylinder full of fuel. Do NOT attempt further engine starts until you remove the spark plugs to give any possible fuel in a hydro locked cylinder a place to escape. Only motor the engine with the spark plugs out to purge excess fuel.
Rick
Old Nov 2, 2018 | 10:28 PM
Thanks Bombardier1. I will try this tomorrow and report back
Old Nov 3, 2018 | 02:26 PM
Ok. Took out the plugs and tried cranking the engine over. Still doing the same thing
Old Nov 3, 2018 | 02:39 PM
Tear-down time....
Old Nov 3, 2018 | 04:56 PM
Anybody know which fuse I pull (under the hood?) to disable the fuel pump. I know...…. it can't be as easy as just stating...….. fuel pump...…..
Old Nov 3, 2018 | 05:15 PM
Sometimes the fuse box lid has a guide....
Old Nov 3, 2018 | 06:07 PM
00paul's Avatar
There are fuse diagrams on google. If you're trying to disable fuel, you can unplug your injectors or fuel supply line if you can't find the fuse. If you try to crank it (or key on) with fuel line off, stick the line in a bottle to catch the fuel from spilling. If you have an air compressor, shoot air in the cylinders and see if fuel comes out, watch your eyes though. I would try hand cranking the engine at crank pulley bolt with a wrench before taking the engine apart. If it rotates with a wrench, you aren't hydro locked. If it doesnt rotate, take off belt and try again. If still not rotating, you may have bent a rod assuming you did have fuel in the cylinder when cranking.
Old Nov 3, 2018 | 08:08 PM
I will try the hand method tomorrow. I found the fuse for the fuel pump is in the trunk on the passenger side. This is pretty scary since the only thing I did was switch fuel rails.....
What's also weird, All but 2 plugs seemed drenched in fuel. I should have just bought an original fuel rail...…..
Old Nov 6, 2018 | 05:01 PM
Finally got around to trying to turn it by hand. It's a no go. Won't budge!!!! I am fuc#@ed
Old Nov 6, 2018 | 06:57 PM
Head-pulling time....
