Ls1 s10
Old Dec 1, 2018 | 04:33 PM
Marc45167's Avatar
Default Ls1 s10
Won't run backfires act like it's out of time has current performance wire harness.how can I go about adjusting timing ?
Old Dec 1, 2018 | 06:07 PM
With either HPTuners or EFILive. I doubt if timing is the issue. Check all your grounds. Sounds like a connection problem
Old Dec 1, 2018 | 06:37 PM
Marc45167's Avatar
There is no tuner...just 09354896 pcm and wire harness from current performance it just acts like it don't know when to fuel or fire....is there supposed to be a camshaft reluctor?
Old Dec 1, 2018 | 06:39 PM
LLLosingit's Avatar
You should have a cam and crank sensor connected, Is it an actual LS1 ? If not what year is the engine?
Old Dec 1, 2018 | 08:02 PM
Marc45167's Avatar
Yes it's a 04 avalanche 5.3
Old Dec 1, 2018 | 08:38 PM
LLLosingit's Avatar
The cam sensor is at the rear next to the oil pressure sensor, It reads the Camshaft itself. ( Reluctor built into the cam)
The crankshaft sensor is on the side of the block just above the starter.
Old Dec 1, 2018 | 08:39 PM
LLLosingit's Avatar
Make sure you have your coils wired correctly and not swapped side to side. This would cause your symptoms as well.
Old Dec 1, 2018 | 09:12 PM
Marc45167's Avatar
I've checked this several people has said this but the way the one side is wired for temp sending iac tps and alternator connectors...another guy seems to think that my harness don't match pcm?
Old Dec 2, 2018 | 08:00 AM
Darth_V8r's Avatar
Moderator
One way or other your coils are out of sequence. Backfiring through the intake used to mean you got your spark wires wrong on the distributor or your distributor was on the wrong tooth. Only way that happens on an LS is between the wiring between the ECU and the coil pack. If I had my coil packs in front of me I would be able to tell you which wires go to which cylinders.
Old Dec 2, 2018 | 11:33 AM
Marc45167's Avatar
I put my pcm out of my 99 Silverado has same service number has same senerio now when I unplug the injectors it stops acting like it's out of time and starts to hit I took cam sensor out it has a couple scrapes on it so I'm swapping this out.
Old Dec 2, 2018 | 11:50 PM
Darth_V8r's Avatar
Moderator
I must be missing a step. How does it run without the injectors plugged in?
Old Dec 3, 2018 | 06:51 AM
LLLosingit's Avatar
I don't see where he said it was running?
Old Dec 3, 2018 | 08:00 AM
Marc45167's Avatar
Yeah it doesn't run
Old Dec 3, 2018 | 09:59 AM
Darth_V8r's Avatar
Moderator
Right here is what I misunderstood:
Yeah it doesn't run
OK, that makes more sense. My first thought, and it was more of a snide comment, was "Well yeah, without fuel it can't backfire, so that makes sense", followed immediately by "but wait, how did it run then?"
The cam sensor on a 99 will only get you either on time or exactly 180 degrees out of time, which won't backfire. That's firing at the top of the exhaust stroke instead of the top of the power stroke. When it backfires, unless it's a massive air leak int he exhaust, the coils are more like 90 degrees out of time, which only happens when the coils or injectors think they're on a different cylinder.
A bit of a embarassing story, but maybe it will help you. I put aftermarket coils and and aftermarket coil harness on my TA, and fired it up. Wouldn't hold idle without throttle, tried to rev, fired through intake, smelled horrible, etc. And from the old SBC/BBC/ "anything with a distributor" days, I know this means the spark plug wires are on the wrong distributor posts, but there's no distributor, right? So, I traced the harness wires, figured out which color was supposed to go to which cylinder from the ECU to the connector. I then pulled out the stock coil pack, and sure enough, I had the driver side coils wired 7-5-3-1 front to back instead of 1-3-5-7. I had simply flipped the aftermarket coil pack sub-harness by mistake. Reconnected it in the correct order, and everything right as rain.
I've seen similar things occur when guys relocate their coils to the frame to make space. The harness gets flipped and the car won't run.
Old Dec 3, 2018 | 05:17 PM
Marc45167's Avatar
I sat and thought about this and I came across something..if he bought a wire harness for 04 avalanche which the motor came out of and is using a 99 pcm...is the pinouts the same on these pcm's?
Old Dec 3, 2018 | 07:48 PM
Darth_V8r's Avatar
Moderator
No I dont think they are.
Old Dec 3, 2018 | 09:31 PM
rpturbo's Avatar
Overall I believe the wiring is close enough it should run from 99-04. I believe there are a few grounds in different places, but it should run. Now my question, are you SURE it's a 04 24x ecm, and nothing 58x?
Old Dec 4, 2018 | 08:53 AM
Marc45167's Avatar
The pcm is out of a 99 Vette and I have thought more on this and if I get a response from cpw it could be the case of the wire switched from side to side for injectors and or coils..if the harness ships without loom.im thinking of all possibilities,
Old Dec 4, 2018 | 09:19 AM
rpturbo's Avatar
Did you request it without loom? Mine came in loom, everything marked. Not to say it was perfect. Normally if you have some time, call Jared while your in front of the truck. He will walk through what to check with you. He has always provided great customer service. That's the reason I used him. Well, that, and 8 years ago, he was the only guy who built plug and play harnesses for a s10.
Old Dec 4, 2018 | 01:33 PM
Darth_V8r's Avatar
Moderator
I was thinking about this some more, and I'm thinking maybe you're right. The connector pinout might be identical. IDK about the 99, but the 04 truck ECU would be DBW vs DBC. But the 04 OS is VASTLY different vs the 99. If the motor was 58x and ECU was 24x or vice versa, it would not run. ask how I know... The 04 motor should be a 24x reluctor and 1x cam sensor. IIRC, they made the change in 2006/2007 to the 58x/4x arrangement.
