P59 missing channels
Old Jan 7, 2019 | 06:51 AM
epfatboy's Avatar
Default P59 missing channels
After I upgraded from a 1 bar OS to a 2 bar OS I lost alot of channels, stuff like IFR, Cyl Airmass, etc...Here is what I see now, this is what I see connected and offline. If I change to a offline default vehicle I see just externals.. I do have a ticket in with HPT but I thought I'd ask here too.
Old Jan 7, 2019 | 10:02 AM
RonSSNova's Avatar
Try this.
Connect to vehicle
Then hit the re-poll for supported parameters.
See if that works.
Old Jan 7, 2019 | 10:34 AM
JoeNova's Avatar
Restricted User
I've been having this issue a lot lately. I'll configure and save the channels, even connect to the vehicle, but as soon as I hit scan they disappear completely.
Old Jan 7, 2019 | 11:41 AM
Russ K's Avatar
Go to Hp Tuners > VCM Scanner > Vehicles, and delete the OS files. Then try connecting the scanner again.
Russ Kemp
Old Jan 7, 2019 | 03:06 PM
truckdoug's Avatar
bookmarked that to try later
Old Jan 7, 2019 | 05:01 PM
RonSSNova's Avatar
I’ve done that before as well. But haven’t had to in a long time.
Old Jan 8, 2019 | 07:34 AM
epfatboy's Avatar
I re-polled last night and see more channels for the default vehicle but nothing more for my current vehicle. I also still don't see Injector Flow Rate or Cyl Airmass for the default vehicle so something is up...
I then went out this morning to try again and get a log and the scanner would not connect and showed the following error
I then tried to write a tune and got this error
Working with HPT support now. I wonder if this is related to the new SW release? Also I have not updated the drivers in the MPVI.... maybe there is a sync issue between the SCAN/EDITOR and the MPVI driver.
I'll keep posting and accepting info as I get it.
Old Jan 8, 2019 | 07:53 PM
epfatboy's Avatar
Apparently I missed a critical time tested IT problem solving technique called disconnect the battery and try again.
Problem solved, re-polled and everything shows up.
Old Jan 10, 2019 | 10:01 PM
RonSSNova's Avatar
Sweet!
Old Jan 12, 2019 | 08:51 PM
rpturbo's Avatar
Thanks for posting this! I am getting ready to swap to a P59 on my own, and of course, I will probably have issues since its mine. LOL
Old Jan 13, 2019 | 12:09 AM
subeone's Avatar
I've been having this issue ALOT with 06-07 vehicles recently. Repolling works. Sometimes it takes 4-5 tries.
