After-Throttle low Idle issue
Notice, prior to 22 minutes into the log, your idle was very stable, and spark kind of moved around from 12-20 degrees? Then after that throttle blip around the 22-23 minute mark, it went to straight 18 degrees and that's when idle got unstable? That's one thing we need to fix. Then, at the 25 minute mark, you kill it and restart, and adaptive spark returns, until you blip the throttle again at 26:30.
The other is that you are 16-17:1 on your WB. Are you deliberately running that lean? If not, i'm assuming you know how to correct that. At 26:30 after that throttle blip you're at 18:1. I understand idling lean, but you need some fuel in there. I'm pretty sure that this is the reason it is commanding so much idle trim airflow.
One other observation -- when you are key on engine off, you're only seeing 81 KPa, which I typically expect to see around 100. This has me wondering which map sensor you have. you're on the 3-bar OS, which typically means your running boost...
I will try to dig around some and see if I can come up with a good reason why it will not drop into adaprive spark on return to idle.
A 2000 camaro auto has this for 0/2/4/6/8/10/14/18+mph This is in G/S.
0.0049 0.0078 0.0098 0.0400 0.0996 0.2998 0.7998 1.0000
Does it fall flat only when commanding WOT, or anytime you stab the throttle? I haven't looked at your attachments as I am currently at work.
If it's not in the tuning, it could definitely be one of your guesses. When this happened to me (as in, I was barely able to accelerate much at all, it would fall flat and misfire when giving any throttle too quickly) it was caused by my main feed hose inside the fuel housing in the gas tank coming loose, and providing just enough fuel to cruise at around 2000 or so rpms.
