LS1 No Start
Thank you all!
your fuel pressure should not drop at all. so that throws a red flag right there
what I do to make sure the injectors are working right is I pull pull the entire fuel rail and injectors up out of the intake, with everything still connected to wiring and fuel line, put a towel under the fuel rail assembly and have someone turn the engine over while you watch what the injectors are actually doing. Hell you might even see all of them leaking badly before even cranking
