Initial Startup After Swap
Once my HPT arrives, for “first step” initial testing and startup, I assume I need to disable VATS??
And, is there anything else I need to do and/or any well known issues holding back a engine/pcm swap?
P.S. it’s milled, ported, cammed, long tubed, and LS6 top end’d... if any of that will effect it just simply “starting” so I can check for leaks and what not before going to a dyno/tuner.
