Newbie looking for guidance: P0300 Misfire at idle/Supercharged
Hello everyone,
New guy checking in and looking for some guidance. I am finally starting my build on my boosted Tahoe. What I got is a 2000 Tahoe 5.3L with a Magnuson supercharger (MP112). I picked it up pretty cheap but it needs a little work. I've been around mechanics my entire life but I don't claim to be one myself. I know my limits and I try to stay within them.
Currently it has a significant misfire at idle. I would say it is present about 75% of the time but the other 25%, it runs smooth. The previous owned said he did plugs, wires and a coil on cylinder #6. I've having some trouble getting it pass emissions barely missing the NOx reading. The limit is 2.0 and I am registering at 2.9 but all the other emissions readings pass with no problems. I did an injector balance test on all the injectors and they are all reading about 38# across the board. I took temp readings on each manifold and #6 is running a bit cooler than the others. All cylinders were roughly about 190*+/- and #6 was about 170*. The misfire seems to go away as the RPMS rise as it seems to run perfect past 1000rpms. Can anyone point me in my next direction? Forgive me for being such a noob but we all have to start somewhere right? I look forward to learning about it and fixing it myself. Appreciate any help.
We had some really good ones in the area but the one closed shop and the other wasn’t sure if he could fit the Tahoe in his dyno bay. I think I found at least one of the problems as the fuel pressure gauge is only showing 35psi of pressure I’ll start there..
That WOULD cause your misfire issue. Lack of pressure means lean running at idle and possibly other areas,
Fuel pressure regulator or pump? Like I said, I’m learning but I assumed 35psi was plenty of pressure till I started researching what normal was. I was still in the world of 24v Cummins that only needed 17psi.
Either/or. Check pressure AHEAD of the regulator. It better be above 60psi. If it is, the regulator is the culprit.
That's not even a leak, more like weeping; Would not affect pressure readings.
What alternator and pulleys are you running? It does sound like you’re running lean at idle but it’s interesting that it would clear up once engine speed increases above 1000 rpm. Makes me suspect the fuel pump isn’t getting enough voltage at idle but fuel delivery improves as the engine rpms go up and the fuel pump gets more volts with more alternator output. It would be easy to check alt output with a volt meter.
Well put in a Walbro 450 today, removed the extra inline pump after the fuel filter and no change. Fuel pressure stays at 38psi but now bleeds off with the key on?
