525hp GM crate engine start but no run
G atsma gets the chicken dinner! Swapped in another e38. Fired right off and settled into a lumpy idle on a stock 2008 Corvette 6.2 tune. Thanks for all the input. At least I confirmed my wiring blueprint for LS3 into Miatas is correct. Shout out if you need a schematic!!
I had similar issue when installing a sniper system. The engine started because of the initial fuel prime but die immediately. Turns out I had the tach signal hooked up wrong. Sniper would not add fuel once started because it sensed the engine was not running.
