AEM Wideband wiring question.
Old Mar 4, 2019 | 11:16 AM
Dano 00TA's Avatar
I just checked the adapter and it is installed and working. I used a program called Accessport to check send/receive and according to the test, it's working correctly. Was able to open/close the port with the program and by jumping pins 2-3 was able to auto send and receive text with this test and it passed. And I am getting voltage to pin 2 (.47volts) I'm using this for the gauge blue/ground.
Old Mar 4, 2019 | 11:21 AM
Dano 00TA's Avatar
Should I still try to install the drivers for it or do you think it's ok?
Old Mar 4, 2019 | 11:28 AM
Dano 00TA's Avatar
One thing, I have the black wire from the gauge grounded and I'm just using another ground for the adapter? I'd assume this will still work correct? Or does the black wire from the gauge go directly to the adapter?
Old Mar 4, 2019 | 04:27 PM
dlandsvZ28's Avatar
If you got a readout from the Hyper Terminal substitute application on your laptop, then your connections should be OK.
BTW- you haven't said yet if your AEM gauge is displaying AFR correctly when you start the car. If it is then the readout in HP should be nearly identical to the AEM gauge once you get HP up and running.
I don't recall now, since I have changed my wide band back to EFI live, but as I recall (7-8 months ago) I had to complete the 'transform' step in HP in order to get the channel to display the AFR after connecting the scanner and starting my car (98 Z28). I have an AEM -30-4100.
Recall it was something like this in HP setup.
"On the rear of the 4110 is a small rotating switch....what mode are you using the wb in...Lambda or AFR? For AFR I believe the switch needs to be in P0 and for Lambda needs to be P1. Check out the manual for these correct settings."
" .... in the Scanner, select the MPVI A/D Input 1 channel, close the channel select window, click the MPVI a/d Input 1 channel and select Transform. Transform Selector window will open. Select Oxygen Sensors and the either Air-Fuel Ration or Equivalence Ratio depending on which mode you selected above. Find the AEM 30-4110 label and double click.
Should be good to go...
hth
Old Mar 4, 2019 | 06:54 PM
Dano 00TA's Avatar
hth
Yes, it's reading fine on the gauge, just disappears on hp tuners. I'm using the AEM X-band 30-0300 and there's no switch on the back. I did see a transform thing but don't have a clue on what to do with it. lol Must be something I'm not doing right in hp to set it up. This is so frustrating.
Gonna go out there now and try to look for what you said in the setup.
Old Mar 4, 2019 | 07:24 PM
Dano 00TA's Avatar
I did find the transform selector and see AEM 30-(03X0,2340,5130) so I selected that but it also has this "Function (Input/ 1) + 0 = output" where I can change the 1 and 0? Would these need to be changed?
Old Mar 4, 2019 | 08:28 PM
Dano 00TA's Avatar
Still disappears when I try to scan.
Old Mar 5, 2019 | 10:51 AM
dlandsvZ28's Avatar
Sorry - my mistake. Missed or forgot that you have the AEM 30-0300XXX series.
The instructions state that it is not backward compatible with any LS PCM's pre-07. However, in another section their instructions state says that the serial connection is backward compatible with the 30-4000 and 30-4100 models. Most everyone on this forum has had success connecting the MPVI2 model using a serial to USB cable with the 4100.
The HP Tuning school videos also state that 30-300 is not backward compatible. ?????
So you might contact AEM. One would think by now that if there are success stories out there, that AEM is aware of them since the LS crowd is still buying their products. I don't think they market the 30-4100 models much anymore.
I see you posted on HP also but still answer.
Just for kicks you might try selecting 30-4100 from 'TransForm' and test again or try adding a channel using external input and see if 30-4100 or 30-0300 is an option. With analog the PLX wideband is the same as AEM
Lastly - INSTALL the FTDI drivers that came with your cable. Perhaps the chip software drivers Windows installed isn't converting the data correctly. What do you have to lose?
Sorry, can't help anymore as my only experience is with the 30-4100 series.
Old Mar 5, 2019 | 11:45 AM
Dano 00TA's Avatar
Guess, I'll keep messing with it and see if I can come up with something. I'll try your suggestions though. Like you said, what do I have to lose. Thanks!
Old Mar 5, 2019 | 12:42 PM
pdxmotorhead's Avatar
You probably actually need pins 2,3,5...... 2&3 are the transmit receive pair for serial some USB adapters will not work in receive only ,, they need the transmit pin so they can handshake with the device.
You also may need to explicitly tell the software your using Xon-xoff or NO flow control to let it stream the data, if its set to hardware flow control (Which you shouldn't need.) you'd need more wires and a more complex wiring scheme.
Random google result:
https://www.decisivetactics.com/supp...h-serial-cable
Old Mar 5, 2019 | 01:07 PM
Dano 00TA's Avatar
Where would pin 3 connect if it were needed? I found flow control. Gonna try the other settings you mentioned now.
Old Mar 5, 2019 | 01:15 PM
  #32
It's in the diagram/link, basically the 2 serial ports connect together, as pictured, depending on the whim of AEM.
You have to identify the pins on the AEM, then the pins on the cable connector, its either a straight through or a null modem connection.
Pretend the USB to serial adapter is inside your laptop, just relate the 9pin on the adapter to the 9 pin on the AEM (If it has a 9pin,, I have a Innovate )
I don't use HP tuners either so I just know the hard wire part.. But I have hooked up literally 1000's of serial connections I started in IT when terminals were the big deal.
RS232 is just 2 pins for transmit and receive and a signal ref (Pin 5) If you look at the adapter above with the screw terminals the circuit board has the functions of each pin on it.. Since you pointed out that shorting the 2&3 pin caused activity, that's a good sign you need 3 wires for your specific application.
Old Mar 5, 2019 | 01:21 PM
  #33
Looking at your AEM pic, I would bet there is a rs232 pinout for that connector in the manual, since AEM chose a non standard rs232 connector.
You need to find the "rec" and "xmt" pins and then pretend the AEM side looks like the link I posted..
Worst case try it with the 2&3 wires each way it will work one way or the other.. (see the two diagrams in the link thats the only difference.)
Serial voltages are low they won't hurt them selves unless AEm did something incredibly stupid..
Old Mar 5, 2019 | 02:05 PM
  #34
Dano 00TA's Avatar
This is the pinout for the gauge, I see only 1 serial wire?
Old Mar 5, 2019 | 02:09 PM
  #35
Dano 00TA's Avatar
I'd just go the analog EGR/AC route but now I'm not sure if that'd work with this gauge either now. Sent AEM a message about it on Facebook but haven't gotten a reply yet. If worse comes to worse then I just won't be logging any readings.
Old Mar 5, 2019 | 05:14 PM
  #36
Dano 00TA's Avatar
Oh well, out of luck going serial. AEM got back to me and said I'll have to go analog to get HP Tuners to recognize it. So now I gotta figure this out..... Would it be easier to use the EGR over AC since I have no EGR now and I'd assume if I use AC that I'd need to run a toggle switch to go back and forth between tuning and using my AC, correct?
Old Mar 5, 2019 | 06:17 PM
  #37
dlandsvZ28's Avatar
Try this before giving up. If this doesn't work - you still have the option of getting the HP Pro Link data logger.
Try this - open your VCM scanner. Click on Help to make sure you have the latest update 4.2.1
Remove the existing channel by right clicking. Choose remove channel
Click Add a Channel
From the dialog box that displays choose 'External Inputs' (this is an external wideband)
Below that choose Serial Port
Below that choose AEM
When it opens choose AEM - AFR
Close the dialog - red x upper right corner of dialog box
Choose the Channel tab again
Your AEM channel will display
Choose channel and right click
From the drop down choose 'Transform'
A user defined dialog box will open
At the bottom click on the blue hyperlink (click to insert or change)
Towards the bottom of the list choose fx -transforms
Choose oxygen sensors
Choose air-fuel ratio
Choose fx - 30-(03x0, 2340,5130) > double-click (that desciption will display later)
Choose 'yes sounds good' and click
The user defined dialog box will display again -type in a description if the description did not populate - it's a descriptor to define your channel
You need to enter two values for the function - these values are specific to AEM
For input type .543
For output type 10.3
Click OK
Now test>
Turn on the key - if all is well a value should display as the gauge/controller checks free air
Start the car - if all is well the AFR value should display same as your AEM gauge/controller
Since I don't have anything to test with - this is as far as I can go since I have a 4100.
Good luck - hope this works for you.
Old Mar 5, 2019 | 06:19 PM
  #38
Dano 00TA's Avatar
Going out there now to try it. Thanks for all your help and everyone else that's trying to help me!
Nope. Same thing.
Old Mar 6, 2019 | 10:28 AM
  #39
dlandsvZ28's Avatar
I went back thru previous posts - # 23 in particular.
"One thing, I have the black wire from the gauge grounded and I'm just using another ground for the adapter? I'd assume this will still work correct? Or does the black wire from the gauge go directly to the adapter?"
It appears you did not use a db9 cable and instead used the green plug end shown in post #21.
In your post #23 above, are you referring to the green plug as an adapter? The blue wire from plug receptable B on the AEM gauge back side should be inserted into pin # 2 receptacle on the green plug end and the black ground should be inserted in p# 5 receptacle on the green plug end. Your green plug end should plug directly into the male end of the serial to USB "adapter".
The serial to USB adapter drivers:
Did you install the drivers?
HP Tuners setup:
The HP Tuners tutorial for the MVPI2 and AEM 30-30X0 series used the 30-4100 instead of the 30-030x0 in the user defined setup. So you might try it instead.
The HP Tuners tutorial used .543 and 10.3 for input and output. However, the values that HP inserts when selecting 30-4100 are .5 and 10. Just speculating but I assume with all of their testing the Tuning school have found that .543 and 10.3 is more accurate. Your reading was .47 volts.
The statement below is from the AEM instructions.
"Serial (RS-232) Output
BLUE WIRE = Serial Out
The serial datastream is suitable for output to third party devices such as data loggers, PCs, or reflashed ECUs. The X-Series UEGO serial datastream is
designed to match AEM's legacy 30-4100/30-4110 UEGO Digital Gauge for backwards compatibility. The currently selected display mode (lambda or AFR)
will dictate what is output via serial. The format is simply the value followed by a carriage return and line feed, e.g. "14.7\r\n"
Parameters for your virtual com 5 serial port:
rate 9600 bps
data bits 8
parity None
stop bits
FYI:
New ERA Performance states that their testing shows that you can data log using either the serial or analog output from the AEM 30-03X0 series with HP Tuners.
See attachment below from New Era Performance:
This link has a lot of useful information explaining how to data log with analog instead of serial. If AEM states that analog works with the 30-03x0 series you might try analog. If so, it looks like you have to tap into the wires from receptacle A on the back of the gauge. Note that the fx inputs for analog are different.
https://forum.hptuners.com/showthrea...Wideband/page2
Old Mar 6, 2019 | 11:21 AM
  #40
Dano 00TA's Avatar
HP Tuners setup:
rate 9600 bps
data bits 8
parity None
stop bits
FYI:
Sorry, guess I kinda screwed up my wording for that "adapter" I'm also using this cable:
Amazon Amazon
And I have the blue wire from the wb going to pin 2 on the green plug and black/ground going to pin 5
I did install the drivers from the company's website to see if that helped.
The Com 5 serial port is setup like what you have posted.
Also tried the 4100 parameters but still disappears, even using the values you've given me.
I was really hoping this way would work but apparently, I'm not very lucky. Didn't want to go analog cause it looks like it's gonna be a pita to setup having to go through the ac or egr on the ecm.
