AEM Wideband wiring question.
BTW - were you actually getting voltage readouts on your laptop when you tested with Hyper Terminal?
Not all USB ports are created equal either. They must be powered and they need to supply 5 volts. I've encounter USB ports that won't drive some external hard drives so I had to use a cable with two USB ends to get enough power to drive the external hard drive.
So you might try swapping USB ports if you have more than two USB ports (one for your VCM scanner and another for the wideband).
I would also visit the New Era Performance site. Their documents states HP tuners works with the 30-30x0 series AEM controllers. Perhaps they will provide some insight into the setup they used for serial with HP.
I created a second math parameter that gives a percentage above or below the commanded AFR from the computer. It's basically [(wideband AFR - commanded AFR)/commanded AFR]*100. Negative numbers mean you remove fuel, while positive numbers mean you add fuel.
For example, assume a commanded AFR of 12.5 and measured AFR of 11.5, the result is [(11.5 - 12.5)/12.5]*100 = -8%. The number is telling you that the car is running 8% too rich, and you need to reduce fueling by 8%.
Likewise, assume a commanded AFR of 12.5 and measured AFR of 14.5, the result is [(14.5 - 12.5)/12.5]*100 = 16%. The number is telling you that the car is running 16% too lean, and you need to increase fueling by 16%.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Which AEM model series?
Scanning serial or analog?
What model year - pre -2007 or post 2007 using Can bus?
Scanning serial or analog? Serial, or you wouldn't need the adapter, right? Unless I'm missing something....
What model year - pre -2007 or post 2007 using Can bus? Whatever I want to use it on. Not reliant on the OBD2 plug with a serial connection. To answer your question, 2003, 2008, 2010, 2012 Silverados.
Which AEM model series? https://www.amazon.com/gp/product/B0184TSI84/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
For vehicles that are 08 and newer AEM 30-030x0 series can also send the data stream thru the OBDII port - and about 10X faster. It's all explained in the ERM attachment in the link.
So, all said, it looks as if you and the OP both have HP MVPI2 and the same AEM wideband series (03-0300).
So what the OP needs, if you will share, is what steps you took when you initially set up your wide band to MVPI2 so he can read AFR or lambda. Others on the HP forum have the same issue with the AEM 30-0300 series in that the data stream AFR value won't display in the PID field, but not so with the AEM 30-4000,4100, and 4110 series.
IMO, it's perhaps the offset values that he is using to compared to what you are using. The devil is in the details.
Thanks in advance.
To OP. It might be a good idea to uninstall the MVPI2 software and reinstall. Might be a file that is corrupted. Check your Microsoft Net Framework version.
- 2 GHz CPU
- 4 GB RAM
- Microsoft Windows® 7 or better
- Microsoft .NET Framework 4.6.1 or higher
- USB Port
Oh, also since I'm running speed density, I can't use the command AFR right?
Serial by the IEEE standard NEEDs minimum of 3 wires,,
it will work with 2 "sometimes"(pins 2&3) If you're lucky..
with one wire + ground its possible get a read only data but wtf..
What EM is doing is providing a transmit pin, and a ground, which will let data stream out,, but there is
no return signal so no handshaking, in this scenario its a total crap shoot what will work with a given serial port.
The truly sucky part, is that there is no such thing as a UART that doesn't provide a TX and RX pin, so
they simply chose to do it half assed.. Or custom programmed their chip and somehow are programing
a spare pin as a simple output signal.
The engineer that did this needs hung with a serial cable over a tank of sharks.. And lowered slowly..
I go go off on a AEM rant but life I too short..
