P0132, P0134, P0155 Car runs terrible!
Back story: I recently bought a 98 Camaro that had a head/cam swap, long tubes ( I've got exhaust leaks probably less than a foot after the o2s. rear o2s deleted) and all the other associated stuff that typically goes along with a head/cam car and 0411 PCM swap. since owning the car I've noticed a few things that weren't put back together very well and i have p0132, p0134, and p0155 codes; all oxygen sensor related and the car runs like ****. i replaced the O2's and still have the same problems. I've read tons of other posts and i'm convinced its a wire somewhere but i'm not sure how to go about figuring which one. i checked power and ground at the o2 connector and they both seem good but i'm not sure how to go about checking the readings for the tan and purple wires to the PCM. i'm curious if there is a short somewhere between the connector and the PCM? I also felt around the back of the driver cylinder head and noticed three ground wires. One of them was broke or I broke it when i was feeling around. I haven't fixed it yet but i will. I checked each one of the three grounds using the ohm setting and two came back 0.000 and one read OL (one of the grounds that were actually connected). I've also read that it could be a MAF or Temp sensor? I dropped it off with the tuner and he didn't want to do anything until those issues were sorted. Please help and thank you in advance!
One code left. P0134?
Its getting better! I only have P0134 now. I've replaced O2s, completely new exhaust from headers back (old system had tons of leaks plus I wanted something different), and checked the wiring for power and ground. Only thing I haven't checked is the tan/wht and ppl/wht for open to the PCM. I'll try to do that this weekend. I'm thinking its possible the wires may have been switched around with the rear O2s as well. I'm just wondering if anyone has any other ideas. If the wires are good then I'm completely out of ideas. By the way, on a scanner the O2 just constantly hangs around .45v, bank two oscillates as it should.
I figured out my P0134!
well, i disconnected the PCM and the O2 to check for open in the wires and they turned out to be good. I scratched my head a few times then decided to look at the pins themselves in the PCM, and there it was! Pin 69 was recessed so it wasn't making contact, causing the P0134. hopefully this helps someone in the future and thanks to everyone that helped me.
