Holley Terminator and Sniper
and then the sprinkle of tac modules and pedals and different OS's for them all
yeah that might be pretty hard actually
Meanwhile C6 guys are spending $7k+ to incorporate Holley into the vehicle and keeping the stock ECM so the dash works for just what Darth said above. Having fully rewired my last car I'm sure I can do it, just haven't sat down and looked into the wiring diagrams to see what a C6 dash needs to work. But if guys can make a Porsche dash work with an LS swap I'm sure we can get a GM dash working with Holley.
That would involve having several different harness for auto, manual, Z06, C6 there is no easy one plug n play harness. There are a couple C6's, camaros and a G8 out there with dominators and working clusters its just a lot of time which equals a lot of money. We can take the stock cluster out and put in touch screen a lot faster vs making stock cluster work.
AC Delco PN 213-3521, GM PN 12589867 – Commonly used on 1998-2006 GM LSx engines. Baseline Frequency – 11.1 kHz
They show Holley 19lb to 48lb, You might contact Holley and see what they suggest.
Should be just a "simple" can translator and 2 wire hook up to the stock harness.. Put the info needed by the gauges on the GM network.
Does holley publish their can data?
What exactly are they doing? Are they just keeping the dash working or are they also keeping the ABS, Traction Control, Airbags etc all working as well? What are they doing with the accelerator pedal, spitting the signal?? There is a HUGE difference between just making a dash work and fooling the vehicle into thinking the stock ECU is in control.
What about states that have smog or at least have inspections? You'll never be able to legally piggyback a stock ECU off an aftermarket, sure some people might be able to get away with it but when you do get cough its not going to end well for someone.....and it's not the person using it thats going to be in serious trouble, its the person/company that made it possible.
And a lot of the foreign car dash boards are easier to make work then most domestic stuff.
