Holley Terminator and Sniper
Old Mar 20, 2019 | 04:23 PM
LSX Power Tuning's Avatar
Default Holley Terminator and Sniper
We finally got the new terminator and sniper systems added to our store.http://www.lsxpowertuning.com/online...=0&sort=normal Not only do we sell, install and tune Holley products we also offer tech support for everything we sell. Please give us a call if you have any questions about any Holley products.
Old Mar 20, 2019 | 07:02 PM
Darth_V8r's Avatar
Moderator
How do you like using them?
Old Mar 20, 2019 | 07:11 PM
We love using holley products, we sell and tune holley efi every week. The sniper is very impressive for what it is. We will be posting a sniper setup in a c10 in the next couple weeks. The terminator systems just came out last week, we have sold some but haven’t installed one yet.
Old Mar 20, 2019 | 07:14 PM
Darth_V8r's Avatar
Moderator
I am very curious about the terminator. Really looks well featured. Also the custom tables, how to get them working if one wanted to create a custom multiplier table for example
Old Mar 20, 2019 | 08:22 PM
The software for terminator isnt out yet, believe this week its getting released. It will be most likely very similar to the sniper software is our guess.
Old Mar 22, 2019 | 09:07 PM
Formula81's Avatar
Can you do a speed density tune with this?
Old Mar 22, 2019 | 09:54 PM
I was told it is speed density only; no MAF.
Old Mar 22, 2019 | 10:09 PM
Formula81's Avatar
Well that would work for me then. Thanks
Old Mar 23, 2019 | 10:38 AM
truckdoug's Avatar
the holley rep I spoke with said the software for the terminator x will be based on the HP, just less IO's
Old Mar 26, 2019 | 08:06 PM
Be more like sniper software most likely but sniper is like dumb down hp basically. Most holley reps have not seen the software yet, including mine. We check every day waiting for the release, we have sold several terminator and terminator x setups, cant wait to get software.
Old Mar 27, 2019 | 08:10 PM
Terminator X Windows Software is now available on the Holley Support page. Its just like the other software, which is awesome.
Old Mar 28, 2019 | 09:49 AM
truckdoug's Avatar
damn it looks really good. very intuitive UX
i'm impressed
Old Mar 31, 2019 | 11:22 AM
truckdoug's Avatar
DQ:
so i'm setting up a base fuel and spark tables for my turbo car. its there a way to select a block of cells and input the same number into all of them? havent found it yet
Old Apr 1, 2019 | 12:34 AM
DQ:
just highlight those cells and type in number and hit enter
Old Apr 1, 2019 | 09:53 AM
truckdoug's Avatar
haha of course its the easiest of all possible solutions so i didnt even bother to try that lol
Old Apr 1, 2019 | 04:13 PM
I spend hundreds of hours a month in holley, efi live, and hpt tuners and still find stuff all the time, not a big deal. I learn alot helping people because they usually look at something completely different than I am or ask I question in a way I never thought of. If your not learning new stuff your not paying attention what someone once told me.
Old Apr 1, 2019 | 07:04 PM
LLLosingit's Avatar
Here is a list that was posted by S2H on the Holley forum that is helpful.
Several people have asked me if there were any HotKeys in the software, to make
navigation faster using a keyboard instead of having to use a mouse to navigate.
So I thought it would be useful to post on here for anybody to see.
The first set of HotKeys applies to just about any Windows based software.
If you Left Click & Hold the mouse button down, and Drag it you can Highlight several cells at once:
CTRL+C will copy those cells to the Clipboard.
CTRL+V will paste the copied items into the currently highlighted cell.
CTRL+Z will Undo an Action.
CTRL+Y will Redo an Action.
(There are limits to how many times you can use the Undo/Redo.)
Specific to the Holley Software.
Right click and a small menu pops up with ways to Cut/Copy/Paste, Smooth vertical/horizontal/all values, or to Fill/Offset values.
Anytime you click on/Highlight cell values:
CTRL+Up/Down Arrows = Change by +/-1%.
CTRL+Left/Right Arrows = Change by +/-5%.
CTRL+X will Zero out the cell/highlighted area.
If you click inside the visual chart area of tables, whatever point you highlight, you can use the up & down/left & right arrows to move/adjust.
On 3D charts, the CTRL+Arrow keys works the same as when looking at the cell values.
Using ALT+[Key]
A = Acceleration Enrichment
B = Boost Setup
C = Trans Shift Parameters
D = Drive-By-Wire Settings
E = Engine Parameters
F = Base Fuel Table
G =
H =
I = Target Idle Speed
J =
K =
L = Learn Table
M =
N = Nitrous Parameters
O =
P =
Q =
R =
S = Base Timing Table
T = Ignition Parameters/Rev Limiter settings
X = Cranking Fuel Table
Y =
Z = Target Air/Fuel Ratio Table
Hope this helps people who like to quickly navigate, using the keyboard instead of the mouse
Old Apr 1, 2019 | 07:13 PM
All that is in the instructions that are in the software. I bet 95% of the questions and calls we get about holley are right there in the documention that’s included but no one reads it. Holley has great documentation included with it. Same could be said about hpt also.
Old Apr 2, 2019 | 01:02 PM
truckdoug's Avatar
oh boy oh boy oh boy
Old Apr 2, 2019 | 01:14 PM
Darth_V8r's Avatar
Moderator
I tell you - if a company were to make a hybrid harness that allowed you to run the stock ECU (crank, cam, VSS, etc) in parallel with the custom ECU so the stock computer can run the factory dash vs splicing wires the old fashioned way, there is money to be made. I bet there are people out there who would pay an extra few hundred for it.
