5.3 LS first start with issues
I have built a 5.3 from the block up using flat top pistons, a mild cam and LS6 intake and injectors. Still using the 5.3 throttle body that I polished.
I have built the engine on a stand and sent the PCM off to LSX Power Tuning in Texas with a complete list of all the mods and specs on my build. (below)
Gen 3, 2003 New old stock 5.3 LS iron block, deburred.
Gen 3, Stock crank, balanced and polished with Speed Pro main bearings.
Gen 4, Connecting rods with ARP rod bolts and Speed Pro bearings, balanced with crank.
Gen 4, Speed Pro 4.8 LS flat top pistons with Speed Pro rings and floating wrist pins. (10.2:1 CR)
Trick Flow camshaft P/N 30602001 and ARP cam sprocket bolts.
Trick Flow double row roller adjustable timing chain and billet gears with Trick Flow chain dampener.
Melling standard volume and pressure oil pump.
Trick flow LS7 hydraulic roller lifters
Reconditioned 862 cylinder heads, Ported and polished with three angle valve job, 2” Manley LS1 SS Intake valves, 1.55” Manley LS1 SS Exhaust valves and Trick Flow double valve springs.
GM MLS head Gaskets and new TTY Mahle head bolts.
Texas Speed & Performance chromoly pushrods, 0.080 wall thickness, 7.400” Intake, 7.350” Exhaust.
Stock 1.7 ratio rocker arms with Straub trunnions and bronze bushings.
LS6 intake and fuel injectors. Fuel Injectors reconditioned and flow tested by Witchunter Performance in WA.
LS1 balancer, water pump tensioner and accessories. 187 degree thermostat.
The problem I am having is that the engine will start but rev high. After a few seconds the idle starts to come down but if I give the engine a rev it will rev but then immediately die. I can keep it running if I play with the throttle after the rev but inevitably it will die. It does restart immediately but idles high for the first few seconds then works its way down to an idle of about 750 RPM as it warms up.
I have added a link to the youtube video I made yesterday of the issue.
About half way through I notice a leak at the cylinder head that I thought was oil, turns out it can’t be oil as there4 is no pressurized oil in the heads and is most likely coolant from the steam vent line that has a slight leak. I will fix that in the next day or two and confirm.
What do you guys think? Should I contact LSX Power Tuning and ask them about the tune? Almost everything on this engine is new including IACV and I used AC Delco or Delphi sensors exclusively.
BTW this engine is going in a 2003 BMW 330Ci
Any help, direction or ideas would be appreciated.
Any secrets to setting it?
If you have a friend with HPT or EFI live, scanning is completely free and can allow you to adjust the IAC down where it needs to be (using the throttle blade, opening reduces counts). Then it's just a matter of getting your adaptives right, idle spark, base running airflow, VE, MAF, and the IAC itself. IAC Effective Area changes will also change the "desired airflow" so the RAF table will need to be revisited a few times while adjusting it in the tune. Any actual changes to the tune will require credits. HPT would cost 2 credits.
No one really likes idle tuning I think (especially cold start idle tuning), because it can be pretty tricky to get everything to play nice with a nice cold engine and nice cold weather involved. Adds a lot of factors to the tune that aren't normally present at operating temps, where practically every other type of tuning is done. Also considering, you can only check your idle adjustments once a day with a truly cold engine, maybe twice if its a cold day.
I wish I knew someone local to the Cincinnati area who could come out and plug into HP Tuners for me. Any idea how I could find someone like this, I would be happy to pay for their time.
I looked at the throttle body idle screw as I was leaving for work this morning and it looked like it was probably not too far off, but I'm sure a little bit of adjustment could make a big difference in engine idle. My visual guess is the idle screw was sticking out about 1/16".
Thanks for your comments on the test stand. Its really just a standard engine stand that I made a pair of legs for that attach to the engine mount locations on the block. I used a super cheap pair of block style engine mounts between the block and legs for cushion. I bought a used Camaro rad and fans off craigslist and made a simple shelf style holder for them.
I suspected it would be doing some troubleshooting on this engine and I wanted to be able to do that and have it pretty close to perfect before I put it in the car.
Really nice thing about doing the swap on a BMW is that the whole front end comes off, so no lifting over the core support.
Last night I installed a new TPS and fired it up again. Started right away and idled pretty well after an initial high idle.
I did adjust the idle set screw on the TB out just a little to where the butterfly is just beginning to open.
I had Torque Pro hooked up for tach, temp and data logging.
Same problem exists as before, in that if I rev the engine it then wont hold idle and dies.
You will also notice the engine revs to around 2000 on start then slowly goes down to the 900's over 30 seconds or so.
Attached is the log file, please have a look at it and tell me what you think. The main issue I see is bank 1, LTFT at -15 and bank 2, LTFT at 25, how do these numbers help me diagnose my improperly running engine?
I think my next step will pull the intake manifold and make sure I don't have an intake leak somewhere, possibly because of the RTV water dam I made in front of the knock sensors.
Question: The part on the back of the LS6 intake that the MAP sensor plugs into is kinda loose. Not terrible but it moves a little if you wiggle it. Looks like there is a rubber seal about 3" diameter that does not appear to be serviceable. Should I try and seal it better somehow?
After that I will pull the injectors and test them. They were rebuilt by Wichunter performance a couple of months ago, but I suppose its possible one or more got some **** in them from the fuel rail when engine was first started.
But the same problem still exists. It fired up and idled OK ish up until closed loop but eventually stalls out. I can sort of keep it running f I fiddle with the throttle but its hard to keep it going and if I let off will die out and stall.
So passing the intake smoke test now, what do I look at next, injectors or coils? Injectors were rebuilt but coils are of unknown age and origin.
Trying to keep positive but I am starting to run out of ideas.
Keep in mind, it doesn't take much air at all to cause a bad O2 reading. A pin hole is enough if it's anywhere before the sensor.
Tonight I will try the hose in the rubber glove over the exhaust outlet and blow air in through the exhaust outlet while spraying soapy water around the exhaust gaskets pre O2 sensors. If that tests well I will swap sensors side to side and see if the LTFT moves with the sensors.
But here's the thing, wouldn't it idle properly when cold and only act up after the O2 sensors come on line?
Should I be focused on the bank that has positive or negative fuel trim? (Bank 1 Negative 15 LTFT, Bank 2 positive 25 LTFT.
Thanks again for your help Chopper.
I will be looking at the wiring tonight, I could easily have plugged my O2 sensors into the wrong banks. Not sure this explains the cold start issues but if this is my fuel trim issue I will be stoked.
