Variable charging system
Old May 14, 2019 | 11:40 AM
andy burdess's Avatar
Default Variable charging system
Hello all I have a 2005 silverado. Is it possible to some how get the variable charging alternator to just target 13.8 all the time. Tired of the variable operation for towing camper. I have EFI Live and can shut down codes or whatever needed. I’m just looking for a consistent voltage all the time.
Old May 14, 2019 | 12:18 PM
How is it affecting your towing? There are thousands of people towing with that setup with no problems.
Old May 14, 2019 | 01:44 PM
If you don’t have any insight please don’t post.
Old May 14, 2019 | 02:00 PM
I need to know how it affects towing to know how to offer a solution for you. Go back to bed and get upon the RIGHT side...
Old May 14, 2019 | 04:34 PM
i stated what I was after in the post. I don’t want to argue with you and have encountered you on this site before. Please move on. Thank you.
Old May 14, 2019 | 07:03 PM
You are after a solution to a nonexistent problem. Good luck.
Old May 17, 2019 | 03:41 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
A simple google search would have given you all the info you need to get a constant voltage alternator setup. Your hostile response to a legitimate question reeks of trolling.
Old May 17, 2019 | 09:10 AM
I’m not trolling. I have argued with the other gentleman in the past and preferred not too again. My alternator is new and charging system up to snuff. The engine is aftermarket and my tow haul is used for an alternate set of **** points with no tcc lockup for aggressive driving without a trailer. I was just curious if there was a way to fool the system to stay at 14 to better charge my camper batteries up on my way to and from camping. A lot of mine is done at places where I run off batt or generator and it would be nice. I did google it and the only clear solution was rig it and risk overcharge or switch to previous alternator set up and alter the harness to accommodate which I’m not totally against. Just curious if someone had an alternate method of fooling this system. If this is going to turn into a large argument with people rallying to the defense of G Atsma where I politely asked him not to respond anymore I’ll just delete it.
Old May 17, 2019 | 11:40 AM
Well. You finally say WHY you need constant voltage. That was all I was asking about. Now be a good boy and listen to gametech. BCNU
Old May 17, 2019 | 12:23 PM
I picture you as a mid twenty something angry young man lashing out to the ls1tech world while smashing sugary overly processed cakes sitting in your parents basement. Or maybe a middle aged man who ls swapped his 3rd gen with a rats nest for a wire harness and an angry wife always mad wondering why you would ever sink endless amounts of cash into said 3rd gen. Please leave my thread. I’m glad I helped you get your post count up for the day now buzz off.
Old May 17, 2019 | 01:24 PM
None of the above. I don't know what I could have said on a previous thread, but you don't take friendly (and it IS that..) advice well.
I picture YOU as a spoiled little kid who kicks and screams when his little show (this thread) does not go according to script. My first post here was friendly and non-abrasive. Yours have not been. And quit thinking of this as YOUR thread. You only started it.
