IAC counts going to Zero! Hanging idle!
I have played with everything in the tune tht I can think of. I also had this issue with a stock tbss intake and ptm 92mm tb. I swapped to the holley high ram setup thinking it would help fix a cracked intake etc. Didn't work. I have been fighting this for a few weeks.
I can close tb blade all the way and counts still stay at 0. Ive checked all vaccum sources, intake leaks, etc. I cant find anything.
I have been tuning a lil over 4yrs and this is the first time ive had an issue like this tht I couldn't figure out. if anyone has any ideas im all ears. thanks.
Air essentially controls the rpm range (+/- off of target) at idle, spark maintains the target. If the rpm setting is too low for that cam, it’s not going to reach the “range” using air because vacuum (airflow) is reduced at low rpm. Try bumping the rpm up by 15-25 at a time until the counts stabilize.
You can can play with spark a bit too, but with different setups the targets are all dependent on mods.
I think we’d all like our big *** nasty merican cams to idle at 550 but unfortunately physics has other plans...
Remove TB, shine a light behind it, see how much light gets through. If a lot, build up with epoxy or ditch the eBay TB for a NW
Thin counts go to zero and it seems like timing locks out and idle just hangs back up.
Ill try pulling the tb off and give it a look over. I feel like it is suspect at this point. Ill also try an idle around 950ish if tb checks out. Ill report back my findings. Thanks guys!
I removed tb yesterday. I shinned a light behind it like stated above. There was a noticable gap on top and bottom. Blade wouldnt fully return to a complete shut on the stop.
I loosened the 2 screws holding the blade and let it recenter itself. It will shut completely closed now.
Only thing tht sucks is i have a hole drilled into the blade. Whats the best way to close it up? Epoxy?
I jb welded the open air passage. Imma gonna try and drill it back out. I think this will allow alot more air for iac to work properly. Hopefully this cures my cold start issue! Thoughts?
Only thing is the cold start still sucks ***. I still have to pedal it for a few seconds on cold and hot start.
May need to play with the throttle follower table for some throttle swings.
Also ive always just added like 50 cam counts for start up airflow. It doesnt seem to be enough. Does anyone have any ideas on chnages to add more startup airflow? I could live with the way it idles if it would start up on its own!
Other than tht, Straightening the throttle blade seemed to have helped alot!
85 iac counts is a bit high for warm idle. I would try to work down to 30 counts at warm idle now that you got the primary issue fixed
