Need help with 98 411 swap tune and clutch wiring
Hello, I’ve had my pcm swap done for almost a year now. I ended up just ordering a mail order tune from a reputable tuner and while the car runs much better with the tune, and I am more than happy with that part of the tune, I still have no fuel gauge. I tried contacting the tuner again, but haven't gotten a response. Its possible my emails didn't go through (it happened a few times while discussing the tune). Any idea on what to check physically on the car that could be an issue? I just repinned it again today and made sure the pins were in the correct spots and correctly in place.The fuel gauge does move a little when I turn the key so I know the gauge isn't a dud. I pulled the tune from the pcm to confirm it was the tune I was sent and that it did download (I got the tune through email). Is there anyone will to take a look at my tune that knows what they are doing? The car is getting a cam and heads soon, but I know the fuel gauge is a bit unique and my dyno tuner doesn't have experience with that so thats the whole reason I ordered the tune. And lastly, anyone know how to wire in the clutch switch so I do not get the code? Thank you all for your help!
Fuel segment swap no longer needed.
Can you check the tune?
You just need to enable PWM for the gauge, use 140.63 Hz for the PWM frequency, modify fuel tank volume and invert the tables.
When repining the harness, the fuel level output signal should also have been changed from red 36 to red 38.
Thats it.
Thats it.
