Diagnostic HELP PLEASE
New motor runs fine, so far, but is hard to start, sometimes, and is throwing a p0343 code, occasionally.
I have replaced the cam sensor, already (Std. Ignition)
My tach is not working either, as it was before, my z28 threw a rod.
Shreve's Engines, out of STL, says to replace the crank sensor, for hard to start issue.
Any thoughts on part, or all of this, would be appreciated.
As always, thx for everyone's infinite wisdom, and experience!!!!
This explains why, my tach isn't working as well.
What are the odds, of a new cam sensor, being bad, as well as the original??
The car isn't starting, no gauges work, etc.
(Yes, the battery is fine.)
Trying to change that out, without removing the steering column.
Cam sensor location is one of the differences between 3rd and 4th Gen engines.
I called Shreves Engines, out of St. Louis, and they basically said, OOP's!!
We forgot about this!!
They are looking to find me a front cam sensor timing chain cover setup.
Shreves missed this fact and didn't inform me, about it. Maybe they assumed, I knew this, when I picked the new motor up.
They are going to repair this for me, by installing a new LS2 timing chain cover with front sensor, and extended harness.
Also, the ignition switch/gauges not working/not starting issue, turned out to be a shorted starter wire, blowing the 50amp fuse.
Thx for all the input, as always.
