50% fuel trim..... Please help!
Now I got all other issues figured out and I got him to change the settings back to 75lbs and I put in New o2 sensors. Now it still shows 52.3% trim and I can rev it up to about 3200rpm very gradually, at which point it goes into open loop and doesn't come back to closed loop until you restart engine. Once goes into open loop it won't rev up above 1500. And if you try to rev it up too fast it will go intoopen loop as early as 1500-2000 rpm.
It's currently running off the map sensor. I put an Ls7 maf sensor on and he couldn't get it to run on it. This is NA build
I have checked all the wiring. All the coils are working. Changed plugs. Got good fuel pressure and regulator. I have good compression 215psi on every cylinder. Timing is correct. Temp sensor is good. Tps is good. It idles pretty good in closed loop.
The tuner thinks there's still some kind of a problem I have to fix before he can tune it. Please help!!!
Thanks!
LS2,
L92 heads,
Lq4 crank.
TSP Ls3 stage 3 cam
Ls2 1 signal cam sprocket. Double roller chain
T56 magnum
Bank 2 trim stays steady at 52.3 and bank 1 keeps jumping around in the 40s. Before I changed the crank sensor today both banks were at steady 52.3 trim.
The plugs do show a bit of a lean
You need to check with a wideband in OL. You'll find most shops, at least the shops we personally know will not tune a setup with injectors like that.
Good luck.
If you want to do it right, start over with known fuel delivery (injectors that have accurate data that matches their actual fuel delivery vs PW) and work on correcting the airflow model (SD or MAF, one at a time) in steady state. This is what we show in our training videos all the time to help people keep from banging their heads on the wall.
