EFILive vs HPT question...
Old Sep 15, 2019 | 07:44 AM
99Silver6.0's Avatar
Default EFILive vs HPT question...
Would I honestly be missing out on much if I went EFILive over HPTuners? I can get into EFI for the cost of a license (I was given an older cable). So, investment in HPT will be substantially higher. There’s no special requirement I need in a tuning suite. Just figured it would be a nice tool to have.
Old Sep 15, 2019 | 09:23 AM
kinglt-1's Avatar
From what I have heard EFI live is pretty good...probably better then HPt. However HPt has far more support and a much wider user base.
Old Sep 15, 2019 | 11:50 AM
ddnspider's Avatar
Go efi if it only costs you the license.
Old Sep 16, 2019 | 01:07 AM
CattleAc's Avatar
Originally Posted by 99Silver6.0
I can get into EFI for the cost of a license (I was given an older cable)..
I'd grab that cable in a heart beat. I use HP Tuners, but I'd love to have both. I'd like to learn on both.
Old Sep 17, 2019 | 12:23 AM
RevGTO's Avatar
Pontiacerator
To me that's a no brainer. For the cost of a license it makes no sense to spend the money to purchase an entirely new tuning suite. For a 99 Silverado, EFILive will give you all the tuning power you need.
Old Sep 17, 2019 | 03:35 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I did not see a 99 silverado mentioned, but if that is indeed the vehicle, be aware that that pcm/bcm combo had some glitches that are not found in any other years. I have no idea if this could affect anything the OP has planned or not.
Old Sep 17, 2019 | 07:57 AM
My old truck was a 99 Silverado but, sold it some time ago. I did fight some weird issues in that truck before I ended up putting in a newer PCM. I would be using this cable on my 99 Camaro though. I have some seat time with EFI Live but havent ever used HPT so just wanted to get some input. Appreciate it guys! Gonna go ahead and buy an EFI Live license.
Old Sep 18, 2019 | 01:03 AM
gametech's Avatar
I learned a long time ago that when you see 10 year member under a username, that name is likely not referencing their current ride, lol.
Old Sep 18, 2019 | 06:25 AM
Its all good. I sold that old truck and never felt like trying to get my name changed. Plus, I’ve had 4 Rams since then!
Old Sep 20, 2019 | 12:05 AM
joecar's Avatar
Let me know how you go.
Old Sep 20, 2019 | 01:34 PM
I bought an EFI Live license for the cable. Gonna keep it and mess around with it on my car. Im not a tuning master but, wanted to have it around in case I need it.
Old Sep 20, 2019 | 11:00 PM
andy burdess's Avatar
Efi live for the ls1 pcm is superior in my opinion. The ability to flash different operating systems once the controller is licensed is great for making everything I tune flex capable. I have both and use both on a regular basis just prefer efi for gm stuff
Old Sep 26, 2019 | 12:12 AM
NSFW's Avatar
The thing that makes EFI especially interesting to me is that they have a custom OS that gives you a fuel table with RPM and MAP axes. Whereas GM used one with ECT and MAP, and then added PE on top of it... which just seems really hacky. RPM and MAP (or RPM and load) makes a lot more sense to me, and there's no need for PE with that approach.
Old Sep 26, 2019 | 03:34 AM
gametech's Avatar
I have no idea what you are talking about, because the HPT SD tables have RPM vs MAP. Both do, plus a lot of other tables that may affect them. Perhaps you need a bit more time perusing your software capabilities?
Old Sep 26, 2019 | 10:51 PM
NSFW's Avatar
First, I should specify that I'm only familiar with the P01 and P59 PCMs, so this might not apply to others.
That said... I'm talking about the table that tells the PCM what air/fuel ratio to use. HPT calls it "Open Loop F/A" and EFI Live calls it "Commanded Fuel."
It's not the same thing as the VE table. Both affect the air/fuel mixture, but they have different meanings and serve different purposes. One should reflect the actual VE of the system - there's an objectively correct value for each cell in that table. The other should reflect what mixture the tuner wants - there's tons of room for opinion in that.
(And, yeah, sometimes you have to abuse the VE table to get the results you want...)
Old Sep 27, 2019 | 02:18 AM
gametech's Avatar
Now I understand what you are talking about. The fuel adder for ect vs map is there to keep from frying your motor in an overheating situation. HPT has other tables for normal commanded fuel situations.
Old Sep 30, 2019 | 06:11 AM
joecar's Avatar
Did you get a V1 or a V2 (V2 has LCD)...?
If you need help with anything related to EFILive, let me know, I'll point you to a bunch if info.
Old Sep 30, 2019 | 01:10 PM
Sounds good! Its just an older V1 cable. Figure Itll suit me fine.
