Bye Bye O2
Tighten the STFT max correction to what you want. Typically let it pull more fuel if needed and cut down the max add.
Set PE to 14.63 or leaner depending on what you need based on exhaust and cam overlap.
Set PE mode enable to 0% from 0-1200/1600 rpms.
I typically cut the afterstart coolant temp enrichment as well since its really rich from the factory for a cammed car.
OL idle, CL cruise.
Only "issue" I had was IDLE being too lean, since it was commanding a 14.68:1 AFR.
By running Open Loop, and fattening it up to mid 13:1 at idle, I gained almost 2" of vacuum and a smoother, more steady (consistently) idle RPM.
Now, I am running E-85 (using a flex fuel OS and ethanol content sensor) and, for a few months now, an OL-MAF ONLY tune.
Originally, went OL-MAF to tweak the existing tune after converting to flex fuel...
Car is super responsive now and I've actually not even considered re-enabling the VE table, or any ST or LT fuel trims.
The "hybrid" OL IDLE/CL STFT CRUISE fueling question that turbo_bu asked (and ddnspider answered) while I was typing, was something I was also wondering about (and going to ask), so may give it a try.
I'm sure somebody will chime in how they made their 50 degree overlap setup run with o2's and drive like stock.
BTW, just because some yutz drives his bucking, coughing, wildly loping engine on the street does NOT make it a street engine.
I do think this is a good thread though, I found lots of info on tech forums in regard to O2 problems but no one really posted up solutions.... Maybe the 13111 sensors do suck and I should of got NGK..... maybe should of left my stockers in with an extension harness I dunno. But car loves what he did.
Guys like Pat G have enough experience that they know how to "tune around" those issues and still have the car perform like it should. Nothing beats experience.
It narrows the scope of performance available when all sensors are on board.
An exception to this is Holley's use of a full-time wide band O2 sensor, which greatly reduces the need for the broad spectrum capabilities of the MAF..
I can not for the life of me get this e38 ecm to run CL. Not a big fan of the coefficient system and the virtual VE table thing. Just doesn’t tune like the ls1 pcm.
Anyways it runs far better and fueling far more on using OL. And further more I like the way it runs/drives in OLSD. If I wanted to get particular I could “work around” the OL and use iat for temp correction... but summer is short here and lucky to drive it four times a month during the summer. Weather not to particular different when it’s driven. So OL isn’t really a problem... for me anyway.
OP's cam has 6 degree's which isn't all that crazy.
