Bye Bye O2
Car is LS1 SBE, TFS as cast milled to 61cc BTR bowel blended, 232/236 .600"/.600" 114 +4 advance, LS6 intake stock TB, LT to true duals. If you have a good tuner and problems with your O2 sensors I recommend trying this route. Pat G tuned my car and its nice to have it running hard again. Feels like I picked up RWHP getting rid of the rich condition.
Just sharing......
Do you see any issue with running it like this?? Or have you experienced failing O2's?? I tried Bosch 13111, and Denso all seemed to last up until maybe 1 or 2 big rain storms.
Side note when my car was bolt-ons only I had the same issues with O2 sensors.
solution of course is to tune it without trims on and then mess with the switching voltage until they don't roll over into pig rich all the time.
hard to imagine doing it remotely though. I'd probably do a OLSD on that and just send it.
So, I agree. It's not so easy to kill o2's.
His comment to me was, I feel comfortable turning your car into an open loop tune that ignores the O2 sensors since it was already tuned on his dyno using the wideband. Perhaps he did some of the things you are suggesting? He is quite a reputable tuner.
I think most good tuners, well if not all tuners shut off LTFT's with a cammed car, especially boosted.
If your tuner is relying on the LTFT to compensate for a shitty tune....well you need a new tuner.
Yes I know some people run completely OLSD or dare I say OLMAF tunes....
IMO, there is no way to account for everything. Let the PCM take care of some of it.
I understand if you run OL at idle(depending on the PCM)to compensate for a cam with huge overlap were the 02's are freaking out.
The few tunes that I have seen where they run OL all the time is because the injector data they have is garbage or the injectors themselves are garbage.
Side note is it true that the older Gen 3 PCM struggles more with the O2 data? That's what in my car.
Thanks for the discussion guys.
