24x torqhead and hptuner questions
Old Nov 20, 2019 | 04:10 PM
Adam1203's Avatar
Default 24x torqhead and hptuner questions
So I ordered HPtuner and got it and i have a torqhead system in my 95 camaro and when i use the scanner it wont see any parameters what am I doing wrong? It does see the ecm though and if I hook a regular odb2 scanner it does work fine.
Old Nov 20, 2019 | 05:55 PM
AgFormula02's Avatar
Assume you clicked connect and also start scanning
Old Nov 20, 2019 | 06:56 PM
Adam1203's Avatar
I clicked connect I didn't click start scanning. I used a different software before where you just clicked connect. I'm still learning the software.
Old Nov 20, 2019 | 08:54 PM
So it works now?
Old Nov 21, 2019 | 09:49 AM
LilJayV10's Avatar
HPTuner doesn't support a 95 PCM.
It has a OBD2 connector but it's actually an OBD 1
The scanner does work but it's very limited what you can see.
Old Nov 21, 2019 | 12:56 PM
MaroonMonsterLS1's Avatar
Lil Jay no ****.
He's using the torqhead kit.
Gives the lt1 the necessary crank and cam signal to work with a P01 aka 411 pcm and hptuners.
So...hptuners will support his specific setup.
Old Nov 21, 2019 | 04:00 PM
LilJayV10's Avatar
Originally Posted by MaroonMonsterLS1
Lil Jay no ****.
I was not aware that kit did that. I do now thanks to you.
Old Nov 23, 2019 | 09:36 AM
Adam1203's Avatar
Yea it worked great.
