Stand alone with cruise control
Gen 4 ECU: I have the original harness, ECU, TCM, and throttle pedal out of the matching truck. I've been reading that these ECUs don't like to work all that well with speed inputs and manual transmissions. Leading me to believe that cruise control is a no go, and also likely needing to get a BCU as well. May have issues getting it to work with Dakota Digital gauges.
Terminator X Max: much more simple, plug and play but no cruise control option as far as I'm aware. Should work fairly easily with Dakota Digital gauges with the Holley converter from Dakota Digital.
Is there any good way to run this engine, with the manual transmission, and retain a cruise control function? Is there a stand alone type option for cruise control function that will work with the Gen 4 stuff? Appreciate any input on this.
https://ls1tech.com/forums/conversio...-dbw-swap.html
