4L80E wont shift as commanded
It's a 2000 TransAm, 6.0, turbo, with a 2 year old Jake's D1 trans and Jake's triple disc converter FWIW
Setting it at 5.00 was a little too much. Reset to 4.00 and it blew the serpentine belt off before I got test it out again
Anyway, I watched a half hour video yesterday, by Cesar Enriquez for trans tuning 6L80e's...He does a lot of high horsepower LS tuning, from what I could see.
Now I KNOW I do not have a 6L80e, lol, but the basics are explained in terms anyone can understand, and he also explains the LEAD TIME function on the BlueCat transmission tuning "app". He was tuning a 700rwhp car, and set lead time to 6.50, so I figured I'd start high (but not that high), at 5.00, which immediately got my shift point on the 1>2 shift, down from 6800, to 5900. I'm aiming for a tad higher, so as soon as rain stops, I'll test the 4.00 lead time setting and go from there...wish me luck.
I'm almost 2nd guessing myself, as 5900, is a LOT closer to 6100 than it was...and that was on wastegate (6#'s). Second guessing because at 14# of boost, that LEAD TIME setting may be perfect...
are you logging line pressures? It might be hanging if the EPC isnt dialed in right.
My old 2000 Camaro, w/4L60e was always much more RPM predominant
My first "test" with the "NEW" BlueCat/Cesar transmission settings, it actually shifted too soon. I decreased the "Lead Time", but it's been raining every day since, so haven't been able to re-test.
I haven't logged line pressures or anything transmission related, except "Current Gear", mainly because with new settings, it actually shifted.
Not familiar with the term, "EPC"? What is that?
you can put a 0-300 psi chinese pressure sensor from ebay and plumb it into the port on the driver side of the trans , just behind the range sensor. log in HP tuners and it'll give you much better insight into what the trans is actually getting as commands go
