spark plug firing WITHOUT engine turning over
Old Aug 8, 2020 | 10:00 AM
tblentrprz's Avatar
The coils will only fire with a pulsed control signal from the PCM. Either the PCM is freaking out or it is seeing a pulsed/trigger signal on the crank sensor input to trigger coils. Time to bust out a meter to see what's going on. Using AC mode to see pulsed/triggered signal can be helpful (when you don't have a scope). Getting comm working at PCM is going to be needed to use HPtuners. Since the PCM had comm when checked on the desktop you may have another module on comm/can bus that is causing the comm issue. Disconnecting the other modules or try pulling fuse that supplies the module to diagnose/isolate problem module.
Old Aug 9, 2020 | 11:50 AM
Creekin's Avatar
Do you have 12v at dlc? Any communication with any other modules? Fuses all good?
Old Aug 9, 2020 | 02:59 PM
talons24's Avatar
What is DLC?
Old Aug 9, 2020 | 03:04 PM
talons24's Avatar
OK, Thanks, I will try that. I had Crank sensor out and hanging, same issue, disconnected, same issue,
Old Aug 9, 2020 | 03:05 PM
Creekin's Avatar
Diagnostic Link Connector
Old Aug 10, 2020 | 07:53 AM
talons24's Avatar
ok, I will check for power there. thanks
Old Aug 15, 2020 | 09:52 PM
talons24's Avatar
Well, traced all wires, found a bad ground, fixed it and that solved my OBD port issue as well as most other issues. got it all back together and upon cranking it backfires through the exhaust. Swapped coil packs to other side, same issue. Put a scanner on and it gives me a Crank position sensor circuit error. P0335 So, as I traced these wires already I am hoping for a defective Sensor. It is a new sensor and i understand it must be learned, but not sure how it can learn it if it isnt running.
Old Aug 16, 2020 | 11:29 AM
Creekin's Avatar
Bad grounds can do weird things for sure!
if you crank the engine, does the rpm register on the scanner?
Do you have the correct crank sensor for the engine? (Grey or black)
Crank sensor relearn should be done after replacement, but will still start and run well, seems to help missfire detection
Lastly, is it plugged in? Done that before, especially when trying to diagnose harness issues and forget to plug it in as its sometimes the most difficult to plug in
Old Aug 16, 2020 | 11:33 AM
Creekin's Avatar
What brand crank sensor did you get?
generally I'll only use oem stuff unless I'm in a pinch,
can you swap your old sensor?
Old Aug 17, 2020 | 07:03 AM
talons24's Avatar
It was a bad Crank position sensor. I replaced it and it started first try and idled. lol Damn car was driving me nuts. I have been working on cars for decades and this time there were so many issues.
Old Aug 17, 2020 | 07:05 AM
talons24's Avatar
I used an AC Delco and replaced with another AC Delco and it started right up. I just got a bad one I guess. Lucky me. lol
Old Aug 17, 2020 | 12:24 PM
  #32
Creekin's Avatar
Right on! Glad you got it fixed up!!
Old Aug 19, 2020 | 06:09 PM
  #33
tblentrprz's Avatar
Which ground was the problem? PCM pin # or Gxxx #?
Old Aug 30, 2020 | 01:23 PM
  #34
talons24's Avatar
it was the ground to the block behind starter. Not sure the number
