spark plug firing WITHOUT engine turning over
Thanks in advance.
I saw this happen of all things with a gas stove. Every once in a while the igniters would just repeat fire - click-click-click - for minutes at a time until it finally stopped for a while. It was the board that controlled the ignitors. If you think of the igniters as spark plugs, which they are, then I would say it points to a bad pcm.
Out of curiosity have you tried unplugging a bank of coils and seeing if the other keeps firing?
We know your coils are good since they all fire and the odds of all 8 failing are pretty slim, really only leaves the cam, crank and PCM as variables in this problem. It's very odd your PCM won't allow communications unless you got that fixed if not I'd look into troubleshooting comm issues to PCM as that may lead you to the root problem as well.
I would probe the PCM connector where the cam and crank sensor inputs come in and the PCM output at each coil and see if one of them is just constantly sending voltage down it like it shouldn't. The coils 4 wires should be from left to right 12v at keyon, control signal, a reference low (from the PCM), and a chassis ground. I'm really leaning to PCM after seeing the wire diagram, I believe that PCM will only attempt to fire the spark 1 time per event from the crank (believe this is what the reference low wire is for as all coils on a bank share it back to the PCM so it can see coil fire events) not continuous like you have and removing the crank and cam connectors I believe should stop this behavior if they are doing something crazy there.
Pinched wire doesn't really make sense as you would have had to mess up a whole bunch of signaling wires and not just a ground or something as then they wouldn't fire at all.
