O2 sensors for ls swap ?
I’m putting an lq4 ina squarebody. I have the pcm and harness from doner truck . But think I will get new harness made. Either way what oxygen sensors do I need. Stock for donor engine. Only the fronts ??? All input appreciated. Thanks
If you are not running converters, you do not need rear O2 sensors. The rear sensor function is strictly to monitor converter efficiency.
