Fresh engine swap-P0327
Old Dec 21, 2020 | 10:02 PM
302LS1's Avatar
Default Fresh engine swap-P0327
Hey guys, I have a fresh LQ4 swap into my Camaro but now I am getting the P0327 code for Knock Sensor low voltage. I replaced both knock sensors when the engine was out. Is there a good way to troubleshoot what the issue could be? If I erase the code, is it safe to drive and see if it comes back?
Thanks in advance
Old Dec 22, 2020 | 06:34 AM
B52bombardier1's Avatar
Hello,
Sure, go ahead and drive it after clearing the fault. Make it a short trip. Are you running anything risky in your engine that would cause knock? High compression, lots of spark advance, forced induction or nitrous?
Rick
Old Dec 22, 2020 | 08:24 AM
302LS1's Avatar
Originally Posted by B52bombardier1
Hello,
Rick
9.5:1 compression, no forced induction or nitrous. I am not sure of the exact spark advance because it was professionally tuned at a shop.
Old Dec 22, 2020 | 09:26 AM
minytrker's Avatar
Did you change the knock sensor harness also?
Old Dec 22, 2020 | 11:19 AM
302LS1's Avatar
I did not change the harness. How would I be able to tell if it is actually knocking?
Old Dec 22, 2020 | 11:25 AM
This hasn't been mentioned, so I will.
Check that all grounds are good.
Check for any bent/missing pins, and that all are connecting solid.
It all seems obvious, but you would be surprised at what gets missed or overlooked.
Old Dec 22, 2020 | 12:17 PM
Good call on changing the knock sensor harness. The connectors on my old knock sensor harness crumbled in my hands when I replaced my sensors. Its a harsh environment at that location.
Rick
Old Dec 22, 2020 | 12:30 PM
302LS1's Avatar
I just ordered new knock sensors and a harness. I will check grounds and such...Would the P0327 code make the motor knock?
Old Dec 22, 2020 | 03:53 PM
The things pointed out in post #2 above are the typical causes of knock with the possible addition of a carbon hot spot in the combustion chamber and low octane fuel. That P0327 code is merely telling you that you likely lack knock detection.
Rick
