Help with hard dip and recover on the dyno
Old Mar 24, 2021 | 05:18 PM
Hammer31's Avatar
Default Help with hard dip and recover on the dyno
Have a 2007 Tahoe LT
BTR stage 2 new springs lifters pushrods
new built tranny with 2000 convert
I take it to the tuner and he gives me this and said I don’t know why it’s doing that.
I don’t have a ton of info but hoping someone has seen this before and can help. Thanks in advanced
Old Mar 26, 2021 | 12:31 PM
Hammer31's Avatar
Anybody?
Old Mar 28, 2021 | 07:10 AM
Hammer31's Avatar
Come on guys just looking for ideas....I think knock sensor kicked in but that the only thing i can come up with.
Old Mar 28, 2021 | 07:37 AM
smokeshow's Avatar
Post the data.
Old Mar 28, 2021 | 09:40 AM
Hammer31's Avatar
I cant seem to get the info from the tuner...he will only give me the graph and said he has no clue. he did not detect the knock sensor in the run.
Old Mar 29, 2021 | 11:44 AM
minytrker's Avatar
1 of 3 things....it pulled timing, closed the throttle blade, or air/fuel changed drastically.
Old Mar 29, 2021 | 12:49 PM
Hammer31's Avatar
The way it totally crashes, length of the crash is the same all 3 runs...and the time it crashes is totally random all three runs.
just so weird.
Old Mar 29, 2021 | 12:53 PM
Hammer31's Avatar
I have done everything right and this is where i am, tuner i guess is holding on to his trade secrets and wont give me any info. Like who do you go to when the tuner cant help me? Beyond frustrated.
Truck is a dog in a rolling start and then kicks in hard before the shift.
Old Mar 29, 2021 | 01:04 PM
QwkTrip's Avatar
Where are you located? Maybe somebody can suggest a different tuner in your area.
Old Mar 29, 2021 | 01:09 PM
Hammer31's Avatar
South Jersey...is this normal for a tuner?
Old Mar 30, 2021 | 11:48 AM
Hammer31's Avatar
Originally Posted by smokeshow
Post the data.
Ok here it is...looks to me like Knock sensor kicked in at 1984 RPM's?
File Type: csv
Old Mar 30, 2021 | 05:31 PM
smokeshow's Avatar
Nothing really stands out in that data. Can you feel it or are you just fixating on how it looks on the graph?
Old Mar 30, 2021 | 05:44 PM
Hammer31's Avatar
Does that not show the knock sensor at 1984 RPM to like 2200RPM? Yes i can feel it,
Old Mar 30, 2021 | 05:55 PM
Hammer31's Avatar
ugh wrong column...2700-2819 RPM
Old Mar 30, 2021 | 07:18 PM
Hammer31's Avatar
Ok so the dip on the graph is at 3200 RPM so its not knock sensor...all im seeing is a ramp up 17 to 19 degrees timing at that point and back down to 18 after the dip.
Old Mar 30, 2021 | 07:56 PM
smokeshow's Avatar
Looks like it's just following the spark surface normally. You could probably stand some more spark advance for sure. But nothing really screams 'problem' here. Those dips are all over the place too.
