Obd2 port not connecting to scanner
Old Apr 12, 2021 | 08:32 AM
Bosshog's Avatar
Default Obd2 port not connecting to scanner
Tried plugging In a normal obd2 scanner to see if it works and it doesn’t. Car is an 02 z28 with an f body harness and pcm
obd port has power
wires have been checked from pcm to port
Scanner isn’t bad, works in my other vehicles
pcm has been replaced as of last year
car starts but runs super rich. Needs a tune though badly since I got bigger injectors for it
all the pins seem to be fine as well
Ive tried unplugging connectors and plugging them back in
all fuses are fine and were replaced anyways
cig fuse is fine
so basically I’m at a loss. Pcm is getting checked today but I highly doubt it’s that...
does anyone have any idea ??
im suppose to be getting a Dyno tune Friday.. and the port is needed for tuning obviously.
Old Apr 12, 2021 | 08:41 AM
Bosshog's Avatar
My car has an 06 6.0 lq4 swap. Along with a th400. Center counsel was removed and all that maybe I cut a ground wire ? But if I did the port wouldn’t have power so it rules that out . That’s why I don’t get it, scanner powers up, tries to connect and about half way through it said it can’t connect.
Old Apr 12, 2021 | 01:48 PM
cobra30689's Avatar
What are your other vehicles? Do you have another older GM you can try the tool on? Be aware the older GM's communicate with the J1850VPW (aka Class 2) protocol, on DLC Pin 2. This architecture has been obsolete since roughly 2005, and newer CAN-based vehicles communicate using high speed data on pins 6 and 14. I have come across some scan tools that are missing the circuitry to communicate with older vehicles. It will power up, but that's about it. If you measure voltage at pin 2, and you have roughly 7 volts.....its not your car, it's the tool.
Old Apr 12, 2021 | 10:17 PM
Bosshog's Avatar
late 90s suburban, 08 Jetta. I’m gonna check voltage at the number 2 pin tomorrow. Also this scanner I’m using worked on my camaro last year..
Old Apr 13, 2021 | 06:19 PM
cobra30689's Avatar
If that is the case I am wondering if you nicked the splice pack under the dash. It's taped (sort of) to the bracketry at the front of the console. All the Class 2 bus devices go to that splice pack for ease of diagnosis. The idea behind it is you can take the plug out and communicate with each individual module by jumping the pins. Does everything else work properly (cluster, ABS, airbag, etc)? They all tie in there too.
Old Apr 14, 2021 | 05:43 AM
Bosshog's Avatar
so yesterday I found out the signal wire isn’t getting any voltage. I took the multimeter to it and whenever I’d check for voltage on pin 2 at the port it can’t get a reading. Pin 16 for turn key power is getting 12 volts like it should, the other two pins for the grounds work. Now that you say that though no my dash is kind of wack almost all my dash lights/codes are on on the cluster. Now granted they’ve always been like that since my car has a completely different trans, motor and diff (no abs) but I didn’t have this problem last year. BUT to add along with that the first time I did my gauges was this year and I was messing with a lot of the wiring underneath the steering column and where the pillar/dome light switch is. I also snipped the clutch wire and spliced that together so my car would start (it’s an auto now, used to be a manual) idk if any of that info helps but yeah.
Old Apr 14, 2021 | 05:53 AM
Bosshog's Avatar
have a pic of the splice pack ? Just not sure which is which. Thanks
Old Apr 14, 2021 | 10:03 AM
Pulse_GTO's Avatar
Check you cigarette lighter fuse, sometimes the ports won't work if that fuse is blown or missing.
Old Apr 14, 2021 | 10:05 AM
Bosshog's Avatar
I mentioned that I checked already, I even replaced the fuses that seemed good just incase lol. My cig lighter connector is getting 12 volts.
Old Apr 14, 2021 | 06:38 PM
cobra30689's Avatar
It's up inside my dash so I don't have a pic of *mine*, but this is a generic photo off Google. Looks exactly like it. Also here is a pic of the wiring diagram....mine is a 2002 but yours *should* be the same.
Old Apr 14, 2021 | 06:48 PM
Bosshog's Avatar
I don’t remember messing with that at all. I’ll check it out but I didn’t see anything. I also swapped pcm’s and it didn’t change anything.
Old Apr 15, 2021 | 05:56 AM
Bosshog's Avatar
Well as of right now I have no idea what the problems is. I’ve checked/tried everything I’ve been told to try. Usually I’d say screw it but my tuner has no way of hooking up to my pcm to make changes while tuning if I can’t figure this out. Unless he removes my pcm every time he has to make a change in the tune in the dyno... lol
Old Apr 15, 2021 | 09:30 AM
timharber's Avatar
I'm a tuning newbie but I found when I was working on my 05 H2 that I had to pull the fuses out for the radio, amp and cruise control and that the scanner could not be set on high speed.
Tim
Old Apr 15, 2021 | 09:34 AM
Bosshog's Avatar
Tim
what is confusing to me though is that my car is set up exactly (wiring wise) how it was last year, which is confusing to me on why it won’t read.. this has been the biggest pita
Old Apr 15, 2021 | 11:29 AM
Bosshog's Avatar
I could try to splice a brand new wire right after the pcm and then run it all the way (skipping the blue connector) and splice right before the obd2 port maybe ?
Old Apr 15, 2021 | 04:27 PM
Bosshog's Avatar
Problem fixed.. green wires leading into the blue connector on pass. Kick panel were backwards (switched). Lesson learned. Thanks for the help.
Old Nov 18, 2024 | 08:36 PM
dfrang's Avatar
Default Spot on!
that’s it!
