Ignition timing retarding under load/ hesitation
It was brought to me for a bad hesitation under load. Truck came in with NO DTCs.
When driving the truck and giving it more than about 1/4 throttle, it feels almost like clogged catalytic converters; like the engine wants to rev up, but can't. (They aren't clogged, by the way; I checked.)
It is NOT misfiring at this time.
While viewing live data on the scanner, I saw that at those times, ignition timing will retard to anywhere from 0 degrees ATDC to -10 degrees.
If you ease off the gas pedal, it goes back to BTDC numbers.
Truck is stock from what I can tell. All sensors seem to be reading normally, fuel pressure is good. Has new AC Delco plugs gapped to specification.
Has anyone ever seen this before, and if so, what was the cause?
If not, does anyone have any suggestions on what to check next?
