E67 ECM / 6l80e TCM compatibility - no signal
I need to get my stalled project going...I purchased what I thought would be a ready to use ecm / harness package for an LS3/6l80e swap from a shop. I have everything installed but getting a communications error and no signal is being sent to the starter. I am getting a Can Bus error - U0100. It seems the BCM and ECM is OK since I can get PIDs and the chimes and the climate control and radio work fine.
I did not realize I would need a TCM programmed to the VIN so that has not been done yet. I have 2 questions -
Can the U0100 code cause no signal being sent to the starter ? I was told by the shop that the communications routes through the TCM and this is why it will not turn over @ all.
The ECM is a "Corvette" based tune which I believe only means I can add select shift/paddle later. Do I need a particular TCM for this type of configuration ?
Normally for a conversion the starter wiring bypasses the ECM, but do you have factory style key on via BCM?
Also normally even if the CAN between the ECM and TCM is disconnected, the engine will start but the trans will run in limp mode - single speed in Drive in 3rd gear.
And yes you need a TCM OS/Cal that is matched with the C6 ECM OS/cal. Same model year preferred for best results. .
The following users liked this post:
mrbtd (11-05-2021)
OK it seems like there is no doubt I have a mismatch between the ECM and TCM. I guess where I am stuck is I only know the OS of the ECM (12632122) I was told the TCM I need is 24275872. Would love to verify that before throwing more $ at it.
The no starter signal has me worried. Of course the shop I purchased everything from is telling me it is because of the TCM issue and they are having trouble getting a TCM programmed so I was looking to move in another direction.
I am using the factory style key via the BCM. Interesting though - if my TCM is not connected the ODB port cannot communicate with HP Tuners (connect).
