Should I Attempt a SD Tune?
I have HP Tuners, but I have next to zero tuning experience. I have watched some great videos on youtube by HP Tuners and it doesnt really seem too difficult.
Is it a good idea to attempt an SD as a newbie with no experience as long as I have a good wideband sensor to monitor my AFR's?
Or should I pay for a base SD mail order tune to get me started and then tweak it from there?
Or should I not even attempt it and take the car to a tuner?
If you did, and you've tuned VE with MAF disabled, then you've basically already done an "SD tune"
I use a MAF-less closed loop tune on my turbo car, using factory O2 sensors for all idle and cruise regions, and only use wideband for WOT.
Personally, as Plan A, I'd probably SAVE the current tune, as-is, then do your MAF-less tune, with the current setup. If you're comfortable with those results, then swap the intake & throttle body and simply tweak it for the new intake setup/parts. IMO, you'll be way ahead of the game, not also possibly fighting new part install issues, and have the option of a simple "start over" reflash if you get in over your head.
If it doesn't work out, with you trying to do the SD/Mafless tune yourself, then you can always reflash the current working tune, and figure out Plan B...
Like ddnspider said above...it'll take a little time, but will gain you some valuable hands on experience.
Regardless, I'd figure that part (DIY or paying someone) out BEFORE swapping parts
You can switch to the "Speed Density Enhanced" OS to eliminate the secondary table making copy & paste from the scanner so much easier. You do have to do a "Write Entire" when flashing the new OS so make sure the vehicle battery and laptop battery is fully charged and DO NOT INTERRUPT the flash or you'll brick the PCM.
If you only have one VE table disregard my above rambling
Its an 0411 PCM "Red/Blue" from a 2002 Escalade. Not sure if I have one or two VE tables.
