Misfire on front half of engine
Did you rotate the engine with the valve covers off and watch to see if its opening and closing the valves?
Pressure test cooling system?
Leakdown the engine. (You may have blown the head gasket between the cylinders.)
Instant fails are often sensors on any EFI motor
I'm puzzled what items could go bad that would cross the engine side to side on 4 cylinders.
You can blow a head gasket without causing any issues with the oil or cooling circuit.
If you blow threw the thin section between 2 cylinders it misfires, But on both sides at once? that would be weird.
If you have white smoke that's coming from somewhere and white is usually coolant.
You can check the insides with a cheap bore scope that hooks to your phone available off places like amazon.
Less than 100 bucks, handiest shop tool ever. Since I don't know the engine specs, I would check Piston 2 valve clearance?
If the line bore was just a smidge off you could have kissed a valve lightly enough to make a leak not hard enough to kill the motor.
and it would happen likely at one end. Totally wild *** guess here.. just trying to brainstorm.. That's where the bore scope would help.
I'd also buy a leakdown tester,, they tell a way bigger story than a compression test.. Pistons/valves/cracked head all in one check.
Harbor freight sells one for light use, if you need to you can put better gauges on it but the rest is basically just a valve and hoses.
Once you practice its a very fast process, I do a leakdown on a sprint car between sessions..
Of course when you can see the whole engine its way easier to get the plugs out LOL
Its also possible you had a electrical glitch and damaged a coil. Or that your fuel system sucked up some grunge and its clogging injectors. But that doesn't explain the white smoke.
Waiting to see what it turns out to be...
If you idle is not changing when you pull plugs, try it with the injectors.. You have either a fuel delivery issue, or a mechanical issue.
I'm running out of ideas now.
Map sensor and pcv are next to check.
