Replacement Ecm VIN question
Old Nov 28, 2021 | 11:39 PM
AntiPeaceMilitias's Avatar
Default Replacement Ecm VIN question
I recently swap out the ECM of a 1998 Camaro Z28 with another from the same year same OS/part number etc ECM from another Camaro, because the first on had an issue with the EVAP purge controller within the ECM.
I did upgrade to unlimited model/year for that specific vehicle and it took 3 credits because I already done 2 1998 camaros before. Anyway all seems fine and was able to save/flash the replacement ECM without any issues...
Now my question is as I have been searching for a few hours but couldn't find the answer to. How to change the VIN number on the new ECM as it has another number from a different car? The VCM editor has no option to do so and the VCM scanner shows the option to change ViN but when I click on it, it says I have no license to do so? Be it I just upgraded to unlimited 1998 camaro and I have licensed the new ECM with 3 (upgrade credits).
Using 4.10.7 software on computer
OS number on both ecm are the same
Year is the same on both
Any help would be appreciated
Old Nov 29, 2021 | 09:02 AM
minytrker's Avatar
I can change the vin but you cant do it with hpt.
Old Nov 29, 2021 | 10:38 AM
Wasn't it available in the MPVI before or?
In any case do I need a tech II or something else to do it?
Old Nov 29, 2021 | 01:22 PM
minytrker's Avatar
I believe it used to be in hpt, not 100% sure. I have never tried changing vin with a tech 2, I have one and used it a ton but dont think it can just change the vin.
Old Nov 29, 2021 | 04:40 PM
Any idea if EFI Live is capable of doing so? Or any other tools for that matter. I just need to match the VIN on the replacement ECM to the car as it's the same year same OS etc
Too bad I couldn't find a replacement ecm for 1998 cars as it's so hard to find here and they stopped producing new or refurbished units for some time and this used unit was my last hope and so glad it worked and wasn't broken or anything. I did a test drive for an hour and all went well with re-flashing it with my old calibration from the bad ECM.
Old Nov 29, 2021 | 04:54 PM
1FastBrick's Avatar
EFI Live can do it.
HPT use to be able in older versions.
A tech 2 will not do it with out completely reprograming the ECU with a subscription or a burn copy of the old TIS software.
Old Nov 29, 2021 | 06:16 PM
Originally Posted by 1FastBrick
EFI Live can do it.
Thanks man. I will be looking into EFI live glad to know before pulling the trigger on the new HPT MPVI 2 as an addition to my MPVI (1).
Old Feb 18, 2022 | 05:27 PM
G FORCE's Avatar
I have a 98 Z28. I just replaced my ecm but found out the ecm came from a 98 w an automatic trans. My old ecm was shutting off power to my fuel system. Now w the replacement ecm fuel pump primes and car will start. But now im getting 8 different codes that are auto trans related and car will only idle for a few seconds then die. I also have no response when i step the gas pedal. The tuner i bought the ecm from said he wasnt able to program my VIN to the replacement ecm. Any ideas on next step?
Old Feb 18, 2022 | 06:34 PM
VATS is shutting your car off after a few seconds. You need to access the tune and get it to "recognize" your car.
Old Feb 18, 2022 | 06:42 PM
G FORCE's Avatar
VATS has been deleted.
Old Feb 18, 2022 | 07:54 PM
B52bombardier1's Avatar
PCM Hammer can change the VIN. And I hasten to add . . . for absolutely free of cost.
Edit: I stand corrected after looking at the PCM type at the top of this thread. PCM Hammer won't work with a standard 1998 PCM. Only the 1999 and up to about 2007 P01 and P59 PCM devices.
Rick
