VATS Disable
Old Dec 30, 2021 | 06:27 PM
sgo70's Avatar
Default VATS Disable
I was trying to get my L83 swap fired up today and it would start up nicely, rumble a bit and die shortly after, like a few seconds total. I keep reading about VATS no being disabled so I ran a quick scan on HP Tuners and looked at the OS. I just got HP and I want to learn more so my understanding is VERY limited.
Under VATS Patch 1&2 it says Enabled......shouldn't this be disabled??? I got it programmed by Speartech so I figured they would know, I'd call them but they're closed right now.
Sorry about the MEGASUPERSIZE view lol.
Thanks,
Sean
Old Dec 31, 2021 | 02:03 PM
rpturbo's Avatar
They are all a little different I believe, but if you look at the system tab, the general, it's listed under security.
Old Jan 2, 2022 | 12:59 PM
sgo70's Avatar
Thanks, I can find it no problem, I'm just not sure if I should switch them both to disable as well as Starter fault checks and then rewrite all???
My son broke my Windows computer so now I have to go buy another one. Perfect timing lol.
